Shuboxlover
Model?
Shuboxlover
Is there enough info in these pictures to tell what model tractor this is?  There is no belt guard and I don't think the shroud for the engine is original.
Thanks in advance,
Tyson
ri702bill
It is a 1962 model....the on-off toggle switch, straight shift lever, and lack?? of a keyswitch says it started out as a 502.....
953 nut
With the battery location I was thinking 552.       :scratchead:
gwest_ca
Could it be a 702?
ri702bill
Not a 702 - look at the serial number tag.... lools like a thumbprint in the middle - that is the unused hole for 1 of the electric start switches. This one was a magneto ignition. The 702 has the tag moved down below that switch....
Battery holder..... came welded in on 502, 552, and 702. I actually have the sheetmetal open-top box from my 502 that took the place of the battery...
Edited by ri702bill
Shuboxlover
Thanks everyone....does this pic help?
ri702bill
Yup - 502 all day long (at least that was how it left the WH Factory)......
Shuboxlover
Awesome... thanks all for the help,  I really appreciate it!!!
Tyson
Mark siebenaler
Do you have any plans as to what your going to do with it?
