76c12091520h 3,624 #1 Posted September 25 Now available at an affordable price : laser cut 110669 / 102943 PTO engagement plates. These are exact replacements for the 110669 and 102943 plates. #102943 has the extra hole for the spring and has been been discontinued by Toro, but #110669 is still available. Ours all have the additional hole as found on the older tractors. Price is $20.00 each plus shipping. Available in red or black. Private message me here, or call / text during normal business hours. No E-mails please. 1 1 Share this post Link to post Share on other sites
peter lena 8,648 #2 Posted September 25 @76c12091520h nice opportunity / well made , made a point of detailing in FUNCTIONAL LINKAGE , LEVER STARTING POINTS . if you washer up / lubricate as you go , the ease of movement is amazing . typically rusty , loose connections only add to the problem . my pto lever start point , and end heim joint connection is ridiculous in its smooth solid connection . went on from there at any connection , pete Share this post Link to post Share on other sites
