toma 12 #1 Posted September 24, 2024 Hi all. I purchased a Wheel Horse 522XI tractor for parts. The engine has 850 hours and after cleaning looks good. I am trying to get the engine running but it won't start. It has compression, spark, and it is getting fuel. I rebuilt the carb but it is acting the same way as it did before it was rebuilt. When turned over all I get a puff out of the carb. When I have the choke on full I get fuel spritzing out of the top of carb (when cranked). It is also loudly backfiring once in a while when cranked. Any ideas what might be happening? Ia m trying to avoid having to tear it apart. Video attached. Thanks engineprob.mp4 Share this post Link to post Share on other sites
WHX?? 50,695 #2 Posted September 24, 2024 Stuck valve? Timing issue? 2 Share this post Link to post Share on other sites
953 nut 57,839 #3 Posted September 24, 2024 Sounds like the intake valve isn't closing completely. This service manual should be helpful. Share this post Link to post Share on other sites
ri702bill 8,954 #4 Posted September 24, 2024 I agree - stuck valve or a heavy carbon buildup that is preventing it from closing. Perhaps timing, but the cough thru the carb says valve... Time to unbolt the head to give it a look see... 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #5 Posted September 24, 2024 Before digging too deep check the valve pushrods making sure they did not jump ship. 1 1 Share this post Link to post Share on other sites
TonyToro Jr. 1,749 #6 Posted September 24, 2024 2 hours ago, ri702bill said: I agree - stuck valve or a heavy carbon buildup that is preventing it from closing. Perhaps timing, but the cough thru the carb says valve... Time to unbolt the head to give it a look see... Share this post Link to post Share on other sites
toma 12 #7 Posted September 26, 2024 Hi All...I removed the valve covers and everything looks good. Valves seem to be working so I removed the heads. The valves heads have a little carbon build-up but nothing major. None are stuck. Is it possible one of the hydraulic lifters is going? Could that be causing these symptoms? Share this post Link to post Share on other sites
