Phan 17 #1 Posted September 20, 2024 Dear Friends, I want to convert the attached mower deck (I got it free, don't know the model) to be used for my wheel horse 312-H. I plan to drill to attach a frame mower deck from the 312-H. Any sugestions? Thank you! Share this post Link to post Share on other sites
Ed Kennell 40,449 #2 Posted September 20, 2024 I converted several decks including this 48" SD. Simple, just attach the support frame to the attach-a-matic and the lift bar. Then position the deck under the support frame and drilll the holes. Here is a pic of how I attached the front to rear leveling rod. I also added two more anti scalp rollers as this deck only had one centered roller. 7 Share this post Link to post Share on other sites
daveoman1966 3,807 #3 Posted September 20, 2024 This is what I did to mount a side Anti-Scalp roller. You could do this on both sides. 1 Share this post Link to post Share on other sites
Phan 17 #4 Posted September 21, 2024 Oh ! Thanks ! Your deck looks mine too. How do you drill a square hole? Do you use any tricks? Share this post Link to post Share on other sites
cleat 6,996 #5 Posted September 21, 2024 3 hours ago, Phan said: Oh ! Thanks ! Your deck looks mine too. How do you drill a square hole? Do you use any tricks? To make a square hole without a punch I simply drill a round hole then use a square file to make it square. It helps to have a carriage bolt handy and test fit it as you file so you don't make the hole too big. If your round hole is the same size as the flats of the square hole then you are only removing the corner material so not a lot if filing is required. 4 Share this post Link to post Share on other sites
953 nut 57,832 #6 Posted September 21, 2024 2 minutes ago, cleat said: drill a round hole then use a square file to make it square Or you could just use a new bole. Share this post Link to post Share on other sites
Racinbob 11,718 #7 Posted September 21, 2024 You can actually run that deck with those brackets. It will mount right up. I ran one for several years that way. I simply used the drive belt setup that the newer tractor used (front mule drive). One disadvantage and it probably would have been OK. When the mower deck was lifted it moved to the rear a little bit effectively tightening the belt to what I felt was too tight. I didn't worry about it during the normal ups and down when mowing but when I was done I'd loosen it some. 1 Share this post Link to post Share on other sites
Phan 17 #8 Posted September 24, 2024 On 9/21/2024 at 8:17 AM, Racinbob said: You can actually run that deck with those brackets. It will mount right up. I ran one for several years that way. I simply used the drive belt setup that the newer tractor used (front mule drive). One disadvantage and it probably would have been OK. When the mower deck was lifted it moved to the rear a little bit effectively tightening the belt to what I felt was too tight. I didn't worry about it during the normal ups and down when mowing but when I was done I'd loosen it some. It is intersting - I wonder if you have pics to post how you mounted it and what the lenght of belt is I need. Share this post Link to post Share on other sites
Racinbob 11,718 #9 Posted September 24, 2024 The mounting is really self explanatory and I don't remember the belt length. Try the belt intended for the later decks and go from there. Share this post Link to post Share on other sites
Phan 17 #10 Posted October 4, 2024 Ok - thank, Racinbob! Share this post Link to post Share on other sites
