mrc 763 #1 Posted 15 hours ago in regards to mower deck belts, is there somewhere on the site that lists spindle belt sizes and pto to deck belt sizes i'm looking for info on 42SD, 42RD and 48SD thank you mike Share this post Link to post Share on other sites
953 nut 54,310 #2 Posted 11 hours ago Here you go. 1 Share this post Link to post Share on other sites
peter lena 8,456 #3 Posted 8 hours ago @mrc belt wear is usually related to pulley lubrication failure , while in the related areas . verify pully smooth easy function , another spot to look at is the deck belt tension spring , is it in a constant violent buzzing state ? if so , your spindle bearings , idler pulley , is showing you the way of cause . typically there are 12 related bearings in the PTO / DECK set up , if there is a bearing acting up , typically lubrication failure or lack of , there will be a rough / noisy , whyining spot , that is telling what's going on . easiest first test is , pto to mule drive down angle belt , can you move / rotate the belt to deck easily ? collective pulley drag , will quickly eat up a belt . also deck itself spindle belt will show , belt wear from bearing hang up . just some insight to regular issue , pete Share this post Link to post Share on other sites
