chev0545 236 #1 Posted September 18, 2024 on one of my 310-8 on the amp meter doesen't register i have power on the terminal is the gauge bad Share this post Link to post Share on other sites
953 nut 63,031 #2 Posted September 18, 2024 1 hour ago, chev0545 said: on one of my 310-8 on the amp VOLT meter doesen't register i have power on the terminal is the gauge bad If the volt meter has power to it and is not working check the ground wire to be sure it is connected. 1 1 Share this post Link to post Share on other sites
pfrederi 19,271 #3 Posted September 18, 2024 310-8 could be K series engine (battery ignition 3 amp charging system) or Magnum with 3 amp or maybe 15amp regulated What do you have??? Share this post Link to post Share on other sites
953 nut 63,031 #5 Posted September 19, 2024 A couple of days ago you posted that after mowing the electrical system seemed dead and a few suggestions were made at that time. Did this problem get resolved and what did it turn out to be? Under the seat you will find an identification tag, the model number from that tag will tell us what charging system and type of wiring your 310-8 left the factory with. Share this post Link to post Share on other sites
chev0545 236 #6 Posted September 19, 2024 it was the pto switch that went bad Share this post Link to post Share on other sites
