JimSraj 450 #1 Posted September 18, 2024 Been trying to find a lift tube (107403) and flag (1986) for a 06-42ST42 05, updated to 79350, at a reasonable price with no luck. Can anyone tell me if these parts from other short chute blowers are the same and will work? If so which ones? As another option it Looks like they should not be too difficult to make if I had all the dimensions of both pieces. Share this post Link to post Share on other sites
ebinmaine 68,887 #2 Posted September 18, 2024 I have a short chute from the mid 70s that I'll be dropping off to @Maz91 Mike in the next few days. I can get you measurements on that if you like. 1 Share this post Link to post Share on other sites
Handy Don 12,663 #3 Posted September 18, 2024 2 hours ago, JimSraj said: they should not be too difficult to make if I had all the dimensions of both pieces. Definitely a (mostly) straightforward fabrication but dimensions are critical--the effective range of the arm on the rock shaft is only about 3” so not a lot of room for “play"! The “flag” component typically has a double bend offset at the rock shaft end to assure the lift force is center-aligned with the push rod going to the blower. Share this post Link to post Share on other sites
ebinmaine 68,887 #4 Posted September 18, 2024 2 minutes ago, Handy Don said: The “flag” component typically has a DOUBLE BEND OFFSET at the rock shaft end to assure the lift force is center-aligned with the push rod going to the blower. It's possible that offset could be created accurately with the CORRECT THICKNESS steel, laid one piece onto the other. 1 Share this post Link to post Share on other sites
ri702bill 8,564 #5 Posted September 18, 2024 I may be wrong, but Lowell sels repro lift flags.... Share this post Link to post Share on other sites
JimSraj 450 #6 Posted September 18, 2024 2 hours ago, ebinmaine said: I have a short chute from the mid 70s that I'll be dropping off to @Maz91 Mike in the next few days. I can get you measurements on that if you like. Thanks Eric. The blower I have is from a 1988. Do you know if they used the same rods and flags? Share this post Link to post Share on other sites
JimSraj 450 #7 Posted September 18, 2024 53 minutes ago, Handy Don said: Definitely a (mostly) straightforward fabrication but dimensions are critical--the effective range of the arm on the rock shaft is only about 3” so not a lot of room for “play"! The “flag” component typically has a double bend offset at the rock shaft end to assure the lift force is center-aligned with the push rod going to the blower. Does the flag slide inside the tube? Share this post Link to post Share on other sites
Ed Kennell 39,229 #8 Posted September 18, 2024 2 hours ago, JimSraj said: Does the flag slide inside the tube? Yes, then flat washers can be used to make fine adjustments to the length. I've made several tubes from 3/4" pipe. I flattened the blower end, drilled a hole and bent the correct angle on the end. Cut to the correct length after the flag is made and installed. Also made several flags from 1/2" round bar and welded two plates one on in each side that sandwiched the lift lever in between. This design puts the force centered on the rod. 3 Share this post Link to post Share on other sites
JimSraj 450 #9 Posted September 19, 2024 3 hours ago, Ed Kennell said: Yes, then flat washers can be used to make fine adjustments to the length. I've made several tubes from 3/4" pipe. I flattened the blower end, drilled a hole and bent the correct angle on the end. Cut to the correct length after the flag is made and installed. Also made several flags from 1/2" round bar and welded two plates one on in each side that sandwiched the lift lever in between. This design puts the force centered on the rod. That flag design is exactly what I was thinking of. Now if I had the dimensions for these parts I’d get started. Share this post Link to post Share on other sites
wallfish 17,114 #10 Posted September 19, 2024 21 minutes ago, JimSraj said: That flag design is exactly what I was thinking of. Now if I had the dimensions for these parts I’d get started. Pretty sure all of that info for the flag and lift rod has been posted on here before . Use the search on the upper right corner Share this post Link to post Share on other sites
cleat 6,729 #11 Posted September 19, 2024 Not my writeup but I have this if it helps. Lift rod and flag for 42 snowblower.docx 2 1 1 Share this post Link to post Share on other sites
peter lena 8,878 #12 Posted September 19, 2024 @JimSraj would personally go over LUBRICATED FUNCTIONAL DETAILING , HOW EASILY IT MOVES / LIFTS , used to also set my blower up on a 4x4 width wise , for initial lifting ease . chute height is all dependant on majority of snow type , regular heavy , short chute , light / dry / fluffy , tall chute , would also plan on moving snow with the sun angle to assist in melting blown snow . my snow now is light , blade work , maybe the walking snow blower , pete Share this post Link to post Share on other sites
JimSraj 450 #13 Posted September 19, 2024 16 hours ago, cleat said: Not my writeup but I have this if it helps. Lift rod and flag for 42 snowblower.docx 462.01 kB · 3 downloads Ok, I couldn’t open it on my phone but could on the iPad. Perfect, that’s exactly what I was looking for. Thanks. 1 1 Share this post Link to post Share on other sites
fourwheelhorseman 342 #15 Posted September 21, 2024 I’ve got a tube and flag I’ll sell you, get me your dimensions that you need and ill messure what I have. Share this post Link to post Share on other sites
JimSraj 450 #16 Posted September 22, 2024 Looks like the tube should be about 44-3/4” from the center of the hole to the end of the tube that the flag goes into. Flag at 11” long. Share this post Link to post Share on other sites
JimSraj 450 #17 Posted September 22, 2024 6 hours ago, fourwheelhorseman said: I’ve got a tube and flag I’ll sell you, get me your dimensions that you need and ill messure what I have. Share this post Link to post Share on other sites
JimSraj 450 #18 Posted September 22, 2024 6 minutes ago, JimSraj said: Do you know the model # of that blower you just got? I’m not sure it matters as long as the lift tube length matches what I’m looking for but it would help confirm the 44-3/4” dimension it it’s the same model blower as mine. 06 42ST 05 1 Share this post Link to post Share on other sites
Maz91 212 #19 Posted September 22, 2024 19 hours ago, JimSraj said: Do you know the model # of that blower you just got? I’m not sure it matters as long as the lift tube length matches what I’m looking for but it would help confirm the 44-3/4” dimension it it’s the same model blower as mine. 06 42ST 05 The blower that @ebinmaine dropped on me is the exactly same year and model number you have. I can verify the measurements and get back to you soon if that would be helpful. Should be able to get them by the end of the day tomorrow. 1 Share this post Link to post Share on other sites
fourwheelhorseman 342 #20 Posted September 23, 2024 21 hours ago, JimSraj said: Looks like the tube should be about 44-3/4” from the center of the hole to the end of the tube that the flag goes into. Flag at 11” long. I’ll measure tomorrow and I’ll get back with you. Share this post Link to post Share on other sites
JimSraj 450 #21 Posted September 23, 2024 3 hours ago, Maz91 said: The blower that @ebinmaine dropped on me is the exactly same year and model number you have. I can verify the measurements and get back to you soon if that would be helpful. Should be able to get them by the end of the day tomorrow. That would great. It should be correct if it’s the same year and model. Where are you located? Will you ship? Share this post Link to post Share on other sites
Maz91 212 #22 Posted September 23, 2024 2 hours ago, JimSraj said: That would great. It should be correct if it’s the same year and model. Where are you located? Will you ship? Oh my mistake, thought you were looking for measurements to fabricate the parts. Share this post Link to post Share on other sites
JimSraj 450 #23 Posted September 23, 2024 9 hours ago, Maz91 said: Oh my mistake, thought you were looking for measurements to fabricate the parts. Sorry for the misunderstanding. I thought you were offering it. I’ll be happy for the measurements if you don’t mind. 1 Share this post Link to post Share on other sites
Handy Don 12,663 #24 Posted September 23, 2024 5 hours ago, JimSraj said: Sorry for the misunderstanding. I thought you were offering it. I’ll be happy for the measurements if you don’t mind. One lift tube that I had (and have passed onward) had a ¼”x 1” bar edge-welded along its entire length as reinforcement. Of course it was cracking at the unreinforced bend where it joined the bottom of the blower. Not sure what year or model that was for. Share this post Link to post Share on other sites
Maz91 212 #25 Posted September 24, 2024 Ok, so I took the measurements and can confirm the attached document by Cleat in post 11 is 100% accurate. 👍🏼 Share this post Link to post Share on other sites
