waylin rayls 5 #1 Posted September 16 hey so imm new but ive got this 1969 charger 10 with a snow plow has the originall motor on it still and original carb but you know it kept blowing heads like lets say every 3 months and it was a great tractor other than that no troubles other than that but then one day i was haulin a lot of logs with it probably had 3,000 pounds on the trailer and i did good the gob done and i started heading to the shop and it started ticking and nocking and my dumb self thought oh well its the heads so i replaced the heads had to put a helicore in it cause i accidentily stripped the heads and it wouldnt start and that wasnt normal it always fired up within 3 seconds even when it was -6 outside so i tried startin fluid and it fired right up then shut right off so i checked fuil puum and it was fine anc=d checked all the other stuff fuel lines and filter thenn i bought a new carburaters but none of them fit so can yall help me Share this post Link to post Share on other sites
waylin rayls 5 #2 Posted September 16 it worked great for about a year so and i bought it for 300 bucks i was only 13 at the time now im 15 and have other garden tractors but im still tryin to fix this one it holds a special place for me it relly has no value Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,078 #3 Posted September 16 You have the Tecumseh engine? Sounds like it is not getting fuel. Have you taken the bowl off the carburetor to see what is inside? Is there a filter in the fuel tank or a sediment bowl under the tank? 1 Share this post Link to post Share on other sites
953 nut 55,522 #4 Posted September 16 Does your Charger have the Tecumseh HH-100 engine. You said the New Carburetors wouldn't fit, were they for the Tecumseh or just for a Wheel Horse? Share this post Link to post Share on other sites
waylin rayls 5 #5 Posted September 17 19 hours ago, gwest_ca said: You have the Tecumseh engine? Sounds like it is not getting fuel. Have you taken the bowl off the carburetor to see what is inside? Is there a filter in the fuel tank or a sediment bowl under the tank? yessir did all that to me i thought its been getting to much air Share this post Link to post Share on other sites
waylin rayls 5 #6 Posted September 17 15 hours ago, 953 nut said: Does your Charger have the Tecumseh HH-100 engine. You said the New Carburetors wouldn't fit, were they for the Tecumseh or just for a Wheel Horse? yes hh100 tecky Share this post Link to post Share on other sites
