waylin rayls 5 #1 Posted September 16, 2024 hey so imm new but ive got this 1969 charger 10 with a snow plow has the originall motor on it still and original carb but you know it kept blowing heads like lets say every 3 months and it was a great tractor other than that no troubles other than that but then one day i was haulin a lot of logs with it probably had 3,000 pounds on the trailer and i did good the gob done and i started heading to the shop and it started ticking and nocking and my dumb self thought oh well its the heads so i replaced the heads had to put a helicore in it cause i accidentily stripped the heads and it wouldnt start and that wasnt normal it always fired up within 3 seconds even when it was -6 outside so i tried startin fluid and it fired right up then shut right off so i checked fuil puum and it was fine anc=d checked all the other stuff fuel lines and filter thenn i bought a new carburaters but none of them fit so can yall help me Share this post Link to post Share on other sites
waylin rayls 5 #2 Posted September 16, 2024 it worked great for about a year so and i bought it for 300 bucks i was only 13 at the time now im 15 and have other garden tractors but im still tryin to fix this one it holds a special place for me it relly has no value Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,483 #3 Posted September 16, 2024 You have the Tecumseh engine? Sounds like it is not getting fuel. Have you taken the bowl off the carburetor to see what is inside? Is there a filter in the fuel tank or a sediment bowl under the tank? 1 Share this post Link to post Share on other sites
953 nut 69,124 #4 Posted September 16, 2024 Does your Charger have the Tecumseh HH-100 engine. You said the New Carburetors wouldn't fit, were they for the Tecumseh or just for a Wheel Horse? Share this post Link to post Share on other sites
waylin rayls 5 #5 Posted September 17, 2024 19 hours ago, gwest_ca said: You have the Tecumseh engine? Sounds like it is not getting fuel. Have you taken the bowl off the carburetor to see what is inside? Is there a filter in the fuel tank or a sediment bowl under the tank? yessir did all that to me i thought its been getting to much air Share this post Link to post Share on other sites
waylin rayls 5 #6 Posted September 17, 2024 15 hours ago, 953 nut said: Does your Charger have the Tecumseh HH-100 engine. You said the New Carburetors wouldn't fit, were they for the Tecumseh or just for a Wheel Horse? yes hh100 tecky Share this post Link to post Share on other sites
