Artmilaca 23 #1 Posted September 16, 2024 (edited) I was told that the performer engine was the same as a 220G and I have that service manual. I went through the ignition system diagnostics and everything seems normal except that coil secondary resistance is 21,500 ohms instead of the suggested 19,800 which to me is not that far off and should not be a problem. The other issue is at the end of diagnostics it calls for connecting a jumper from the positive battery terminal to the positive coil terminal to see if you have spark....... I do have spark Procedure says if you have spark then you have a problem in the low pressure cut out switch if equipped or related wiring and lubricating system such as low pressure that prevents voltage getting to the coil. Problem is I don't know where these sensors are on this Performer engine to be able to check or bypass them for further diagnostics. Edited September 16, 2024 by Artmilaca Clarification addition Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,235 #2 Posted September 16, 2024 Test your ignition switch to see if it is providing power to the ignition coil in the START position and RUN key positions. I don't think you have any engine safety switches. You may be good up to the 9-pin connector between the engine harness and the tractor harness. Post the tractor model and serial numbers so we can look at the wiring diagrams. Share this post Link to post Share on other sites
Artmilaca 23 #3 Posted September 16, 2024 The model is a 520H but I don't know if there is or where the ID tag is on the tractor. My other 520h as a P220G and this one has a Onan Performer 20xls. I seem to be getting conflicting information as to whether these two engines are the same or different Share this post Link to post Share on other sites
lynnmor 7,554 #4 Posted September 16, 2024 The engines are the same. There are no low oil level or oil pressure switches. The 9 pin connector mentioned above is a good place to start. Download the Demystification Guide in the Manuals section so you can trace the ignition circuit to see where the voltage is lost. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,235 #5 Posted September 17, 2024 It will be one of these. Click on the tractor in each and it will take you to a full diagram you can enlarge. When you figure out which is a match for what you have download that file. The ignition circuit has it's own diagram in the file. Share this post Link to post Share on other sites
