powderfinger 24 #1 Posted September 15, 2024 Hey Guys, My battery shows 12V on the multimeter but wont turn over. Where should I begin. Thanks to all! Share this post Link to post Share on other sites
pfrederi 18,074 #2 Posted September 15, 2024 Load test the battery. 12.0 volts is only 25% charged 12.6 full charge. 2 Share this post Link to post Share on other sites
squonk 41,739 #3 Posted September 15, 2024 After verifying the battery is good and fully charged, See how much the voltage drops with the key in the crank position. if it drops more than a couple of volts start looking for a bad or dirty battery cable. also make sure the ground connection at the engine block is clean too. it takes around 65 amps to crank a little 8 horse with a starter /gen 1 Share this post Link to post Share on other sites
powderfinger 24 #4 Posted September 15, 2024 5 hours ago, pfrederi said: Load test the battery. 12.0 volts is only 25% charged 12.6 full charge. Can I load test it with my multi meter? Share this post Link to post Share on other sites
953 nut 56,369 #5 Posted September 15, 2024 1 hour ago, powderfinger said: Can I load test it with my multi meter? Take it to an auto parts store to have it checked. 1 Share this post Link to post Share on other sites
powderfinger 24 #6 Posted September 15, 2024 Is that on your shop wall? lol 1 Share this post Link to post Share on other sites
peter lena 8,933 #7 Posted October 21, 2024 @powderfinger spell check on your internet , will correct TUEN , TO TURN OVER , pete Share this post Link to post Share on other sites
