peter lena 8,878 #1 Posted September 15, 2024 https://www.amazon.com/fascinatte-723-0448-923-0448-723-0448A-923-0448A/dp/B08V4ZVB9D/ref=asc_df_B08V4ZVB9D/?tag=hyprod-20&linkCode=df0&hvadid=693770002238&hvpos=&hvnetw=g&hvrand=4891083975762741296&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1018127&hvtargid=pla-1244579436896&psc=1&mcid=3ffcdb8e1c053480a0ab5147a7bedfdc been adding heim joints to rod ends for years , their 360 degree transfer of thrust , in any sloppy / erratic pull / push point , also dramatically enhances function , add lubrication , snug up entire set up , if you paint it red , no one will know , pete 3 Share this post Link to post Share on other sites
ebinmaine 68,887 #2 Posted September 15, 2024 McMaster Carr. Excellent source. 2 Share this post Link to post Share on other sites
John2189 472 #3 Posted September 15, 2024 4 hours ago, peter lena said: https://www.amazon.com/fascinatte-723-0448-923-0448-723-0448A-923-0448A/dp/B08V4ZVB9D/ref=asc_df_B08V4ZVB9D/?tag=hyprod-20&linkCode=df0&hvadid=693770002238&hvpos=&hvnetw=g&hvrand=4891083975762741296&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1018127&hvtargid=pla-1244579436896&psc=1&mcid=3ffcdb8e1c053480a0ab5147a7bedfdc been adding heim joints to rod ends for years , their 360 degree transfer of thrust , in any sloppy / erratic pull / push point , also dramatically enhances function , add lubrication , snug up entire set up , if you paint it red , no one will know , pete The link is for ball joints Share this post Link to post Share on other sites
peter lena 8,878 #4 Posted September 16, 2024 @John2189 been doing that elimination of sloppy movement connection for years , always look at a , REPEDITIVE PROBLEM , with a change . how about plow lever , end links , pto lever end link , brake / clutch lever ends ? totally eliminate the sloppy movement end point ? functional detailing on almost every movement point , improves it , and it very often does not take much , just how I look T chronic issue , pete 1 Share this post Link to post Share on other sites
