peter lena 8,970 #1 Posted September 14, 2024 https://www.google.com/search?q=wheel+horse+wheel+bearings&rlz=1C1CHBF_enUS866US866&oq=wheel+horse+wheel+bearings&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIICAEQABgWGB4yDQgCEAAYhgMYgAQYigUyDQgDEAAYhgMYgAQYigUyDQgEEAAYhgMYgAQYigUyDQgFEAAYhgMYgAQYigUyCggGEAAYgAQYogQyBggHEEUYPNIBCTEyNDMwajBqNKgCALACAQ&sourceid=chrome&ie=UTF-8 notice the WIDE RUBBER SIDE SHIELDS ? small flat putty knife , pocket flat screwdriver , carefully / easily remove , clean out original generic lube , repack with a 550 flash point grease , hi stress / heat , side loading , play , shucking combines to destroy bearings as well as wheel bearing mount hold point in the wheel itself . this is an easy , simple , upgrade . pictures for reference , if you want original / genuine $ bearings , the improvement still applies , easy to do , add shims .pete 1 1 Share this post Link to post Share on other sites
