hotajax
Zerks Installed at a 45-Degree Angle?
hotajax
On my OEM wheels, a straight zerk is threaded into the hub.  Just curious - how is the drill and tap held at a 45-degree angle during the drill and tap process?
Ed Kennell
The hubs are probably drilled and tapped by a lathe attachment while they are being bored and parted off from bar stock in an automatic lathe.
stevasaurus
You can buy grease zerks that go in straight and have a head that is 45 degrees.  :handgestures-thumbupright:
hotajax
Yeah, I know about the 45-degree and 68--degree elbows.  But I wanted to know how to hold that angle while drilling and tapping.
Chaz54
Do you have a picture of what you are referring to?
wallfish
Why would you want to drill and tap them on a 45 deg angle?
It probably wouldn't work for a grease zerk anyway since the threads on them aren't very long. Plus it could easily get knocked off too
gwest_ca
Could you weld a nut over the hole and use an angled fitting?
WHX??
I know what He's talkin about. I think he's tryin to put them in rims that don't have zerks.
 Had to re-tap many and yes you can't get a tap wrench or drill in there. I just use a small wrench and a 1/4 turn or so is all you get so slow but works.
Learned not to take them out unless absolutely necessary.
If you are using rims that don't' have them just use sealed bearings. Many of use have just gone to not greasing.  Re-grease per greasy pete tho.
1/4-28 is the tap size.
They are available in long thread.
ri702bill
953 nut
If you have a drill press I would suggest you start a pilot hole at ninety degrees to center the bit then clamp the wheel to your drill's bed, tilt it to forty-five degrees and drill into the pilot hole.
wallfish
Absolutely !!! This is the solution even with grease zerks in place.
Do you still think you would want that thing on an angle into a 45 deg hole? Plus that rim metal is thin
hotajax
That's the way the OEM wheel was configured.  I thot about putting in a 45, but i can't get the clearance to drill and tap on that small wheel.  Not much room to work.  I can't even get in there with a grease gun on a straight zerk.  Thanks
peter lena
@hotajax  as referred  , a picture would be nice , however , never let a " sealed  "  bearing stop me from correcting the issue , WRONG LUBRICANT . having done over all my wheels , and also proper wheel shimming , to eliminate side play shucking . the combo of  side wheel play , and ceiling fan lube , does not  make for a reliable set up . personally only buy , bearings with a wide  rubber side grease shield , easy to remove , clean out , repack with lucas polyurea , 550 deg , grease . my entire PTO DRIVEN , set up is detailed like that . imagine no belt / clutch screaming , just smooth easy  movement . wheels are easy , pete
moe1965
If held in place at a 45 degree angle in a vice use a center drill to start your hole then you can drill with the correct drill for a tap.  Can be done on a bridge port.  Drill and power tap.   A machine shop should be able to help you out.
wallfish
Why isn't just using sealed bearings an option? No greasing and no zerks.
All of that extra grease in there does is make a big mess if the wheel ever needs to be removed. Yes it's simple to give the bearings a quick squirt with zerks in place but then again you don't need to do anything with sealed bearings.
953 nut
:confusion-confused:             Are we talking about a front wheel for the Wheel Horse or one of those little mower wheels?
2 red deck wheels and bolts
hotajax
Talkin about the 15" front tractor wheels, not the ones for the deck.
hotajax
So if I understand the people who are in favor of sealed bearings, clean out your bearings, apply premium grease, and reinstall the shields and forget about lubing the spindle?
wallfish
Yup, that's it. The grease in the center of the bearings is just a waste of grease that is there to push grease into an unsealed bearing. It does absolutely nothing to lube the spindle since nothing is even touching the spindle in that area. The only place that needs grease is inside of the bearings. The seal on the bearing also keeps dirt out
Wild Bill 633
Bearing Buddy's come in 1.781, 1.810, 1.938, 1.968, 1.980 diameters. I use them on all of my Simplicities.
hotajax
Bearing Buddy: Pull off the seals on the bearings?
hotajax
I installed new ball bearings, all the way around.  Shimmed up the axle so there is almost no perceptible end play.  The spindle doesn't seem to have any wear rings, yet the one wheel still wobbles, even with the tractor going straight.  Could this be wear inside the hub where the bearing is placed?  Thanks.  314-8 front wheels.
Edited by hotajax
wallfish
That kind of wear or fit you could simply feel by jacking it up and trying to wiggle the wheel.
Maybe a bent rim. While it's jacked up give it a good hard spin and watch it
Ed Kennell
I use BBs on all my boat trailers that I constantly dunk in salt water.    The pressurized hub does keep the water out.    I never felt a need on a tractor though. Sealed bearings work fine on all my tractors.  I do store them inside.
