WHX?? 48,815 #51 Posted October 15 12 hours ago, Achto said: 2 OEM kits in stock ay all times. Shoulda gave me a shout. I was on roll and you was fishin... 12 hours ago, ebinmaine said: Wheelhorses would have a parts dept. I do but it looks like yours ALL the time... 2 Share this post Link to post Share on other sites
953 nut 55,205 #52 Posted October 15 23 hours ago, ebinmaine said: On the 10 to 16 HP .... Trash. The one and only offshore carb I bought was for a 10 HP but listed for 10 to 16 HP. It ran but wouldn't idle down and baulked on throttle-up. It had the 26mm throat which was correct for the 10 to 12 HP but when I opened it up I saw the main jet was much larger which would have been on the 14 to 16 HP engine. That thing was never going to work well on either one as shipped. I changed out the main jet and needle from the old Carter as well as replacing the plastic float and all went well. 2 2 Share this post Link to post Share on other sites
Retired Wrencher 5,454 #53 Posted October 17 @WHX?? Sounds like this three pager is getting close to being done. That is the best part having good friends as a project. I have at one time found one sitting under a deck or a porch for 25 years. Brought that one back to life. I hope you enjoy it. 2 1 Share this post Link to post Share on other sites
ohiofarmer 3,265 #54 Posted October 21 On 9/12/2024 at 8:10 AM, peter lena said: @WHX?? different views , splash pad or oil down ? personally would only oil soak down patina , thats my first transition on any rusty pick up I get . don,t even touch the finish for days , just let it soak in the recovery process , that oiled look would enhance what's there , would also rub it down with a clean oiled cloth , do not , sand or remove any of that base coat . just me , pete I dont really know if pete approves of this, but as a variation on h oil finsh, I rub some 0w16 synthetic oil out of my Toyota Rav 4 oil change on it a time or two and then use the lighter penetrating oil for a couple more applications. On working tractors I don"t know it that makes any difference. Share this post Link to post Share on other sites
peter lena 8,620 #55 Posted October 21 @ohiofarmer regularly " feed " any painted surface with lubrication, especially the older neglected anything , usually like a penetrating type oil spray first , for a spray / soak penetration , also like a warm finish / indoors or outside sun , to enhance paint feed . clean soft cloth with more penetrant , wipe down , might even , luck out with a paint break thru grunge state , at that point , like a 6" electric palm buffer , cleaner wax , usually breaks thru , not a show queen , but definitely better than it was . my 3 horses have all been buffed out with lubrication base . never expect to go from neglect to show queen , very happy to have lubrication based paint recovery , always looks period correct ,another thing about lubrication recovery , is a quick touch up , very easy , always looks good , dust / dirt free , pete Share this post Link to post Share on other sites
Retired Wrencher 5,454 #56 Posted October 22 On 10/14/2024 at 8:28 PM, ebinmaine said: Ya know. You'd think a guy like @WHX?? that has a BUNCH of Wheelhorses would have a parts dept. (Don't mind the mess while we move our workshops and parts storage) Man Eric you got stuff.I am sure it comes in handy tho. 1 Share this post Link to post Share on other sites
ebinmaine 67,459 #57 Posted October 22 2 minutes ago, Retired Wrencher said: Man Eric you got stuff.I am sure it comes in handy tho. And that's only one of SEVERAL areas..... 1 Share this post Link to post Share on other sites
Retired Wrencher 5,454 #58 Posted October 22 Good for you! Man and his parts. 1 Share this post Link to post Share on other sites
