elcamino/wheelhorse
7 " deck wheels
elcamino/wheelhorse
Does anyone know where I can buy 7"deck wheels for my 42 inch rd deck ? I can find 6 " and 8" ,but not 7".
rjg854
Did you try Tractor Supply?
rjg854
Online?
elcamino/wheelhorse
I have looked at Northern , big box store HF , with no luck . I'll try Tractor supply.
elcamino/wheelhorse
@rjg854 Randy thanks for the suggestion  TS sells Martin wheel  7"  all I have to do is check the bore size and off set if any. Wonder where the LUGNUT is whose knows everything ?
squonk
Buy an 8" wheel and turn it into a 7" with a hammer and chisel!
  • Haha 2
Brockport Bill
5 hours ago, gwest_ca said:
Suspect this is the wheel you want to replace. The dimensions are listed
https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=359
this web site says they are canadian located - which makes me wonder if their price listing is US dollars or Canadian - big difference??????????????
Wheel Horse Parts and More sells those wheels but i do not see a size indicated
Brockport Bill
Wheel Horse Parts and More ships
elcamino/wheelhorse
And the lug nut has spoken
pfrederi
at $8  per wheel replace them every couple years...
  • Thanks 1
Handy Don
Be aware of the plastic hub with no bushing in the bore.
These are intended for push mowers and will NOT stand a lot of side force (as might be seen by a deck during a sharp turn or when being mounted/unmounted).
Still, at the price replacing every few years, per @pfrederi is probably a deal!
1 hour ago, pfrederi said:
peter lena
@elcamino/wheelhorse  7" wheels are ideal for a deck , the issue is the construction of the wheel , typically chinese junk , with push in bearings , and weak wheel design . would look look  for a wheel in smaller version for a zero turn mower set up , have personally hunted around for solid wheels , don't   expect to fine exactly what you want , it will be for something else , has to be able to handle side loading , at bearing mount point , would also favor  a smooth tread point , so wheel can slide , and not side grip , that pulls wheel apart . my initial trials were good , but as I went on , the wheel to bearing point just fell apart , might make an axel from threaded rod , so you could elastic lock nut the bearing hold in place . starts to get , repetitive  with issues , pete
  • Thanks 1
elcamino/wheelhorse
I found 7 inch wheels at TS , not stocked in the stores . Made by Martin Wheel ,there are steel with a 55 lb capacity. Should arrive on the 18th . I'll let everyone know how they fit etc. after I get them mounted.
  • Thanks 1
