Rockcrawler69
Wheel hub question
Rockcrawler69
IMG_8647.jpeg.1266fca49a39091fafb3fa07e330a93d.jpegHello,
  New to the forum. Love the wealth of information here. I picked up a new to me 520H last night. Crawling around it I noticed the left hub is farther away from the axle housing than the right. I believe the left has been replaced, it’s black so different color than stock. Is this spacing ok or is there a way to tighten that up?
953 nut
:WRS:
There is very little space between the axle and hub on an Eaton transaxle, yours look about correct to me.
Rockcrawler69
Thanks 953 Nut!
lynnmor
:text-welcomeconfetti:
The 520H tractors have a plastic spacer because the hub runs so close to the transmission.  When you install a hub, leave a bit of clearance.  I think that I see an uneven amount of clearance on your black hub, it may be just the camera angle, jack it up and see if there is some up and down movement of the tire, there should be next to nothing.
Bill D
Looks like the plastic spacer is missing.
Ed Kennell
:text-welcomeconfetti:to the :rs:       Like Lynn noted, the black hub does appear to have an uneven gap with the axle housing.
I would remove the wheel and hub and inspect the axle for damage and try to determine why the hub was replaced.
Rockcrawler69
Thank you. Yes, the black hub is uneven. I’ll jack it up and check.
Rockcrawler69
Definitely excessive play on the black hub!
  • Sad 1
Rockcrawler69
The red one moves about half as much…
Edited by Rockcrawler69
  • Sad 1
Ed Kennell
Afraid you need two new hubs and or axles.
Maybe you'll get lucky and find some "mechanic"  installed 1 - 1/8" hubs an 1" axles and the axles are not ruined.
The good news...removing the hubs should be easier than normal.
Edited by Ed Kennell
Rockcrawler69
Thanks Ed and one can only hope!  I noticed the black hub spacing when I bought it but  $300 for a clean machine and a 60 inch deck I said I’ll deal with it later. Well looks like later came sooner. lol.
Ed Kennell
A $500 60" deck for $300 is a steal....and a free 520H.         Just hope the "mechanic" has not worked on the 60"er.
Rockcrawler69
I hope so too!
Lee1977
Ed I believe that all 1100 Eatons came with 1 1/8" axles and eight pinon rear differential..
Ed Kennell
Yes, they did. but I wonder if that is an 1100.     It's just hard to imagine they can be worn enough to be that loose.    I've seen and repaired  some bad hubs and axles but usually the keyways are just wallowed out.
lynnmor
Never underestimate the abilities of the current crop of "mechanics".
Handy Don
Good thread. Pics of progress would be nice to see!
Rockcrawler69
Thanks for the link Squonk
Ed Kennell how does one tell if it’s an 1100 reared, aside from measuring the axle shafts?
I’m hoping to tear into it this weekend and I’ll take some pictures as I go…
lynnmor
All 520H tractors came with an Eaton 1100 hydro, it is doubtful that a previous owner, that was too dumb to install a wheel, changed the transmission.
Ed Kennell
Like Lynn said, all 520Hs came with the Eaton 1100.     Yes, we are very interested to see the condition of the hub IDs and axle ODs.
Bill D
Agreed.  Hopefully any damage is limited to the hub and not the axle.
Rockcrawler69
Well Ed Kennell called it. 1 1/8 hub on the one inch axle.
Rockcrawler69
Rockcrawler69
