Dawgman
315-8 rear wheels
Dawgman
I have a 2004 Toro 315-8.  The rear wheels are not original. The tires that are mounted are 23x10.5x12.  I want to go back original with 23x9.5x12 tires.  What size wheel do I need to use for the tires?  Thanks.
gwest_ca
What is the width of the wheel you have?
Wheel width is about 1/2" less than the overall width. You measure inside the two lips at the tire beads. Of course it would be easier with the tire removed from the rim but you can stick a rule through the wheel and figure it out.
pfrederi
There is probably more size variation between brands than there is between a 10.50 and a 9.50.  A Carlisle 9.50 will probably be wider than a Deestone 10.50 for example.
rick
Carlisle specs a 7" rim for a 12x9.50-12 tire.
clueless
They will fit the wheel just fine, they are probably the original wheels.
Lee1977
I have 24 x 9.50 x 12 on my 1989 520 with 7" wide wheels.
Edited by Lee1977
