kthomas62
Lower steering support block
kthomas62
I am needing a lower steering support block.
Kevin
gwest_ca
This one? Used by many models so a good used one should be available. Place a wanted ad in our classified section. It is no longer available from Toro.
https://www.wheelhorseforum.com/classifieds/wanted/
Use [Add new classified] in red box.
Include your approximate location. One may be not far away.
ri702bill
Just a note - there are several variations of this block - early ones had thin mounting tabs that are prone to breakage and no thinwalled bushing in the lower hole.
Next they added the thinwalled bushing in the lower hole to the same casting.
The latest(?) is the best choice - it has the bushing and the mounting tabs are thicker.......
oliver2-44
Is your steering lock broken or just worn.
If the holes are worn they can be drilled out and brass bushings installed.
76c12091520h
New and reconditioned are in stock, private message sent. All our reconditioned supports have been rebushed top and bottom and range from $45-$55 depending which one you choose.
Edited by 76c12091520h
  • Excellent 6
ri702bill
Excellent pictures & writeup to what I said earlier.....
