RScheer
Belt
RScheer
What belt is best to use for 52” mower deck on a 520xi Toro wheel horse. I bought one, don’t think it’s right because after short use it shredded.
Thanks for any help.
wallfish
:WRS:
Did the first one shred too?
If so, there might be something contacting the belt which is shredding it. Make sure it's routed correctly. Usually a wrong belt is to tight or too loose or just doesn't perform well, but shredding is something to inspect why that's happening.  :twocents-02cents:
gwest_ca
This is just a wild guess because you did not provide the model number or serial number of the deck. I think there was a change in the front idler assembly that may change the drive belt.
Belts listed on this page. Click on the front page of the manual.
