JRess 12 #1 Posted September 4, 2024 Two issues really Sitting on tractor and turn key and no reaction. If I shake the tractor vigorously it will turn over and starts. All fittings seem tight. when it does run it will shut down. Does restart and runs rough for awhile after coughing out some black smoke. But only runs for a short time. Changed to a new plug no difference. any idea on these two issues? Will also be posting this in another section. Share this post Link to post Share on other sites
rmaynard 15,735 #2 Posted September 4, 2024 I would check all ground connections, with particular attention being paid to the cable from battery to the frame. 3 Share this post Link to post Share on other sites
peter lena 8,878 #3 Posted September 4, 2024 @rmaynard agree on that connection ,battery ground to engine corner / frame , from there to engine rectifier mount point on cooling tins , clean off each spot , like dielectric lube to insure connection / enhance electrical flow . like electrical , cable connections , contractor section , bolt on , very solid . pete Share this post Link to post Share on other sites
Ed Kennell 39,228 #4 Posted September 4, 2024 Yes, like Bob and Pete suggest. I like to remove all positive and negative cables and wire brush contact surfaces. Then install with star washers. The shut down and black smoke start up sounds like it needs the carb cleaned and possibly rebuilt. And a decarbon of the head and cleaning and adjusting of the valves. Share this post Link to post Share on other sites
oliver2-44 9,929 #5 Posted September 4, 2024 As stated above give your electrical system a good going over. While your cleaning the carb and adjusting the valves (if you haven't recently) replace the fuel hose back to the tank and replace the grommet and fuel shut off at the tank which has a small screen in it. Give the tank a good cleaning No need to post the same in 2 different section. We read them all. 1 Share this post Link to post Share on other sites
953 nut 56,185 #6 Posted September 4, 2024 Please do yourself a favor. Address one problem at a time. You have an electrical issue that may be contributing to the stalling. fix that first or you could make the situation worse by chasing ghost issues. Share this post Link to post Share on other sites
