Scott from ontario 3 #26 Posted September 22, 2024 Would I just need the new updated shifter rails or do I need the pin that is posted in the picture was also wondering if the ball on the end of the shifter would make a difference if it was worn down? Share this post Link to post Share on other sites
Scott from ontario 3 #27 Posted September 22, 2024 My grandfather welded the diff casing and the drive gear is worn out on the end I posted some pictures of it and a picture of the shift rails Share this post Link to post Share on other sites
Scott from ontario 3 #28 Posted September 24, 2024 My grandfather welded the diff casing and the drive gear is worn out on the end I posted some pictures of it and a picture of the shift rails Share this post Link to post Share on other sites
Scott from ontario 3 #29 Posted September 24, 2024 Thank you everyone who has been helping me out with the wheel horse transmission I posted pictures of it not sure it that one gear has to be changed also Share this post Link to post Share on other sites
Racinbob 11,702 #30 Posted September 26, 2024 On 9/24/2024 at 10:34 AM, Scott from ontario said: Thank you everyone who has been helping me out with the wheel horse transmission I posted pictures of it not sure it that one gear has to be changed also In response to your PM last night Scott. I can't really see the condition of the inner teeth on your 3523 gear. Here's a NOS and a somewhat worn gear. You could make a 3/4" stop pin if you had to. Just get it precise. Another thing you need to do during assembly. Put it in 3rd gear and just let the stops hold it there. Check the input pulley for any in/out play. There should be zero. If there is any it means the 3523 is separating that much from the input gear. If there is figure how much and shim behind the gear before you insert it in the case. It's a pain because you have to assemble things then undo them only to reassemble again but it's worth it. 3 Share this post Link to post Share on other sites
Scott from ontario 3 #31 Posted September 26, 2024 Thank you everyone who has been helping me out with the wheel horse transmission I posted pictures of it not sure it that one gear has to be changed also Share this post Link to post Share on other sites
Scott from ontario 3 #32 Posted September 26, 2024 Ok thank you do both the new rails need a 3/4 stop pin any chance you have a picture of it with the new stop pin in it I’m not sure at all where it would go. Thank you Share this post Link to post Share on other sites
Racinbob 11,702 #33 Posted September 26, 2024 They are in post #3. They go in from the front of the case. See parts #33, 34, 35. With the 2nd/3rd rail in place (the rear most rail) you insert a 1/4" ball, then the stop pin with the spring, then another 1/4" ball. Be careful as the balls can drop into where the 1st/reverse rail goes. Now the tricky part. Hold the assembly (2 balls, spring and pin) compressed as you slide the other rail in place. The 1/4" balls are at the hardware store . Simple as that. 🙂 Share this post Link to post Share on other sites
Scott from ontario 3 #34 Posted September 26, 2024 Ok thank you do both the new rails need a 3/4 stop pin any chance you have a picture of it with the new stop pin in it I’m not sure at all where it would go. Thank you Share this post Link to post Share on other sites
Scott from ontario 3 #35 Posted September 26, 2024 Would you know the length of the 3/4 stop pins they are not available anywhere I was thinking of getting a piece of 3/4 round bar and cutting them to length Share this post Link to post Share on other sites
Racinbob 11,702 #36 Posted September 26, 2024 The pins are 3/4" long. The diameter is, I believe 1/8" but I'd have to verify that. I can do that tomorrow. Anybody here have an extra 3/4" pin they can part with? Share this post Link to post Share on other sites
Scott from ontario 3 #37 Posted September 26, 2024 Don’t I need two of the pins? And people on here sell parts also ? Share this post Link to post Share on other sites
Racinbob 11,702 #38 Posted September 26, 2024 Just one pin as per the drawing I posted. Yes, there are several vendors here as well as individuals selling stuff. Share this post Link to post Share on other sites
Scott from ontario 3 #39 Posted September 27, 2024 Ok thank you if you can find out that would be great Share this post Link to post Share on other sites
stevasaurus 23,045 #40 Posted September 27, 2024 Cut a stainless steel #6 finishing nail to the 3/4" length. That will work for you. Make sure you have good blunt ends on the stop. 1 Share this post Link to post Share on other sites
Scott from ontario 3 #41 Posted September 27, 2024 So the length Of the new stop pin for the new rails is 3/4 would it be the same diameter round as what is in there now just longer correct? 1 Share this post Link to post Share on other sites
Racinbob 11,702 #42 Posted September 28, 2024 Go back and read the service bulletin I posted. The #6 finishing nail that Steve mentioned will work. He knows these transmissions. So once again. Get a #6 stainless finishing nail, cut it precisely to 3/4" and use it. 1 Share this post Link to post Share on other sites
Scott from ontario 3 #43 Posted October 1, 2024 The parts 33-34-35 are not even in the transmission I just looked and I can’t find the spring on line any help with the type of spring that is in there is really appreciated. Also I don’t see how it would stay in there without falling out. Share this post Link to post Share on other sites
stevasaurus 23,045 #44 Posted October 1, 2024 The spring, stop and detent balls go between the 2 rails. The rails hold those parts in place. Share this post Link to post Share on other sites
Scott from ontario 3 #45 Posted October 1, 2024 Ok when I looked in the hole from the outside I don’t see anything so I guess if I take the rails out that’s when they will come out so it won’t be easy putting the parts in and the rails then ? 1 Share this post Link to post Share on other sites
stevasaurus 23,045 #46 Posted October 1, 2024 Check out this video...shows how this goes together. If your rails are stilll in place, the detent balls, spring and stop are still in there. While this is not your trans, the process is the same as yours. 1 Share this post Link to post Share on other sites
Scott from ontario 3 #47 Posted October 2, 2024 I don’t have the spring and balls in between the shift rails I was told the size of balls I need and what to use for the bar # 6 finishing nail but the spring I can’t find anywhere and info on it also can anyone help me out with info on the spring for it please and thank you everyone who has been helping me out with this transmission Share this post Link to post Share on other sites
Scott from ontario 3 #48 Posted October 10, 2024 Does this look correct for the spring for the 953 trans ? Share this post Link to post Share on other sites
953 nut 57,740 #49 Posted October 10, 2024 12 hours ago, Scott from ontario said: Does this look correct for the spring for the 953 trans ? That is the one, have you called Lincoln at A to Z to se if he can fix you up? https://www.a-ztractor.com/ Share this post Link to post Share on other sites
Scott from ontario 3 #50 Posted October 10, 2024 No I did not I’m in Ontario Share this post Link to post Share on other sites
