little red riding horse
c175 engine cuts out under load
Hi people
So engine runs sweet , drives well .. as soon as i go to engage the cutting deck it dies out, actually stops... out of ideas ! below is what ive done
replace fuel lines to carb
replaced fuel tap , inc new fuel filter and cleaned out fuel tank
checked electric fuel pump , (running and pumping as it should ) original one died few years back
stripped down & cleaned out carb & replaced and checked inlet manifold gasket for leaks once back on
cleaned and re-gapped spark plugs
checked both plugs are working (removed leads while it was running )
think i replaced condensor few years back ...
im thinking fuel starvation but looking at the filter its getting plenty of fuel
What have i missed ? im out of ideas !!
Phil
8ntruck
Is the mower deck turning freely?  Are the pulleys in the mule drive turning freely?
I've got a 42" rear discharge deck that I need to go through.  Last time I used it, it was dragging the engine down to the point that it was not cutting when I engaged it.
Good luck.
lynnmor
Replace the spark plugs, they can cause problems even after cleaning.
Good luck.
Yes all free no binding :thumbs:
One of the few things i havent done.. i actually did all this because it was running really rough back firing and so on ... running nice now but wont run the the decks .. do they prefer any specific type of plug ?
how many safety switches are there for the pto ? i know there is one safety switch under the seat ... just wandering if it could be that ... ill replace the plugs anyhow though because they are old
Many thanks
Bill D
Sounds like a safety switch issue.
PWL216
I agree with @Bill D. If you want to be sure that it’s not the deck causing the issue, disconnect the belt from the PTO pulley. If it still cuts out after that, it’s very likely a safety switch issue.
953 nut
Check the wires going to your seat switch, if they have become disconnected or broken the switch will not know you are in the seat and will cut out your ignition when the PTO is engaged.
So , the wire from the cut out switch under the seat had a break in it ! replaced and all good so thanks for your help ! Also put new spark plugs in... what a difference... so want to take blades off next and sharpen them, what would be the correct size socket ? and are they a right hand thread ?
Phil
  • Thanks 2
953 nut
The threads are right hand.    You will need a 1 1/8" socket and it would be very helpful to have a 1 1/8" open end wrench that has been filed down thin enough to hold the spindle from turning.
Great , thanks for your help !
Phil
