jld 4 #1 Posted August 27, 2024 Seeking a working ignition coil (new or used) for an E125V-N/10964B engine. Onan part number for the coil is #1660799, but every dealer I contacted said they are out of stock as is Cummins as well. Cummins said that they are trying to source a new supplier and there is at least a 200 business day back order lead time. This particular coil has a spark plug lead and a separate cable sheath enclosing the mag wire to kill the engine and a pass through wire (not physically connected to the coil) that connects regulator and tractor charging circuit wiring. I do not need that wire and can just use the wire from my existing coil so any coil perhaps used on non-charging system engines that is physically compatible will work. Hope you can help. Thanks. jld Share this post Link to post Share on other sites
953 nut 62,984 #2 Posted August 27, 2024 Lincoln at A-Z Tractor probably can help you out, give him a call. https://www.a-ztractor.com/ Share this post Link to post Share on other sites
jld 4 #3 Posted August 27, 2024 Hi Richard, I contacted Lincoln as you suggested. He said that he did not have any new coils but may have a used one on another engine he could sell to me. Wasn't 100% sure though and is checking on it for me. Keeping my fingers crossed! I'll let you know the outcome. Thanks for the lead. Regards......Jan 1 1 Share this post Link to post Share on other sites
jld 4 #4 Posted September 10, 2024 Richard, Lincoln located a used coil that he tested for spark before selling it to me. I installed it the other day and my engine fired right up and appears to run fine. This coil variation did not include the pass through charging circuit wire include in the kill wire sheath and just pulled the wire out of the sheath from my old coil and inserted it. Thanks so much for the referral. Without a working coil, I was stuck with a 400 pound yard anchor! Jan 1 1 Share this post Link to post Share on other sites
WHX?? 53,289 #5 Posted September 13, 2024 I may have used parts for this motor as well. Mine is a E140 tho but parts might cross. Share this post Link to post Share on other sites
jld 4 #6 Posted September 14, 2024 WHX, I was able to obtain a used coil for my engine that appears to have done the trick. Thanks for following up. jld Share this post Link to post Share on other sites
