pfrederi 19,256 #1 Posted August 21, 2024 Anyone have a good source for bulk Throttle Choke cable? Part of my problem searching maybe one of terminology what do you call the spring with wire running through it stuff. I had to repair the cable on my C-160-8 that I am renovating. The lever mechanism was OK cable material too short. I have a couple others that need new cable. I wound up buying a long choke cable assembly on amazon an cut off the cable I needed. I have the Z bend pliers so it is easy to make new ones up. Share this post Link to post Share on other sites
peter lena 9,556 #2 Posted August 21, 2024 @pfrederi don,t have a suggestion for cable , but do have a suggestion for lay out and function , like to set up final stage VERTICALLY for excellent lubrication top to bottom effect , also use the numerous small holes in linkage ends , with a small extension spring , pulling on cable assist , like SMALL PREFORETED , metal point added to a screw down point . always step by step for effect , better / worse ? did this on one tractor , quickly added it to the others , very reliable , sooth / easy .3-1 PENETRATING LUBRICANT pete Share this post Link to post Share on other sites
Lee1977 7,456 #3 Posted August 21, 2024 Google " throttle cable wire and housings" It should come right up. 1 Share this post Link to post Share on other sites
squonk 44,860 #4 Posted August 21, 2024 (edited) Taryl's website online store has cable wire and conduit available by the foot. Can't post the link on my phone. https://tarylfixesall.bigcartel.com/category/parts Standard Throttle Cable (Inner Wire) By The Foot! (or Bulk 100’ Ft Roll) $1.00 - $24.99 Standard COATED Outer Conduit By The Foot! (or 50' Roll) $2.00 - $69.99 Edited August 21, 2024 by squonk 1 Share this post Link to post Share on other sites
Eriks Red horse herd 122 #5 Posted August 21, 2024 Try Napa auto parts I have bought bulk 50 ft and 100 ft. In the past. Share this post Link to post Share on other sites
squonk 44,860 #6 Posted August 21, 2024 Doubt any Napa is going to stock bulk cable. My local store has little if any small engine stuff any more. Here's another source. https://www.lawnmowerpartstore.com/throttle-cable-inner-wire-100-ft-roll-for-lawn-mower-size-058-245/ Share this post Link to post Share on other sites
953 nut 63,002 #7 Posted August 21, 2024 I bought mine from Maverick Mower. 2 1 Share this post Link to post Share on other sites
