PWL216 889 #1 Posted August 20 I put this together for my own reference and thought someone else might find it useful. Pls let me know if any errors or omissions… 308-8 86-88, M8 310-8 85-93, M10 312-8 85-95, M12 312-A 86-87*, K301 + M12 312-H 90-92, M12 314-A 85*, M14 314-8 93-01, M14 314-H 93-97, M14 315-8/GT 02-07, Kohler Command 414-8 86-89, M14 416-8 85-92, Kohler K341 (85-86) + Kohler M16 (87) * Onan P216 (88-92) 416-H 90-97, Onan P216 417-8 85-86, Kohler KTQS 417-A 85-86, Kohler KTQS 418-8 87, Kohler M18QS 418-A 87, Kohler M18QS 418-C 87, Kohler M18QS 420-SE 86, Kohler M20 516-H 88*, Onan P216G 518-H 88-89*, Onan P218G 520-8 90, Onan P220G 520-H 88-99, Onan P220G Hydro’s with an “*” are Eaton 700 Transmission. Those not specifically noted are Eaton 1100. 520H's in 1990 have the Forward Swept Axle (FSA) but no gear reduction steering. 1991 and up 520H's have both FSA and gear reduction steering. 9 Share this post Link to post Share on other sites
tunahead72 2,424 #2 Posted August 20 The first two years of the 310-8 came with a K241 engine, I believe the same is true for the 312-8 (K301). 1 Share this post Link to post Share on other sites
lynnmor 7,336 #3 Posted August 20 I believe that 1997 was the last year for the 520-H, correct me if you find otherwise. 1 Share this post Link to post Share on other sites
PWL216 889 #4 Posted August 20 4 minutes ago, lynnmor said: I believe that 1997 was the last year for the 520-H, correct me if you find otherwise. You are correct. Thx! I’ll update this later. Share this post Link to post Share on other sites
PWL216 889 #5 Posted August 20 19 minutes ago, tunahead72 said: The first two years of the 310-8 came with a K241 engine, I believe the same is true for the 312-8 (K301). Yup, you’re right. I’ll fix it. Thx! 1 Share this post Link to post Share on other sites
ebinmaine 67,901 #6 Posted August 20 Nicely done Paul 1 Share this post Link to post Share on other sites
midpack 870 #7 Posted August 21 14 hours ago, tunahead72 said: The first two years of the 310-8 came with a K241 engine, I believe the same is true for the 312-8 (K301). Yes, I have an early (1984?) 312-8 with a K301 in it. Share this post Link to post Share on other sites
buckeyes 213 #8 Posted August 21 (edited) I believe the 1988 416-8 had the M16. I believe they went to the Onan starting in 1989. Edited August 21 by buckeyes Share this post Link to post Share on other sites
Lee1977 6,698 #9 Posted August 21 (edited) All 1985's and 1986's had K or KT Kohler's except the 1986 308 with M8 or the 512 with a Robin. Every thing changed to Magium Kohler or Onan in 1987. Here is a picture of my 1985 312-8. The 85 312-8 has the same charging system as the 310 came with narrow wheels 6" and 12" I changed to narrow 8" and 7" wide 12" Edited August 21 by Lee1977 Share this post Link to post Share on other sites
