Keaton
702 engine rebuild
Keaton
hello, I am rebuilding my 702 engine and need some help, I got the crank and piston in, and I did not put the cam in because I need help on the governor whatever parts came out are in a bag I have the cam and the governor parts, so bassically how do I put the governor back together on the inside and but the cam in right? and I need to align the timing also correct? and one more thing I found out that it is already .010 over so been rebuilt I got it and it looked rough so I took it out. thanks-Keaton
  • Confused 1
953 nut
LAST OUT.......FIRST IN
When you took the engine apart the governor was the last thing to come out and needs to be the first thing to go back in.
@prondzy did an outstanding job of documenting an engine rebuild,   read it from start to finish and follow his advice.
  • Like 4
pfrederi
I have Chapter 12 (reassembly) of the K series Service manual printed out on real old fashioned paper. Then I use an old fashioned pen or pencil and put a tick mark by each step as I complete it...(Have had to go to colored pencils now been through it a few times...)
  • Thanks 1
kpinnc
I print all my manuals and have them in old school binders. I've yet to have the battery die in one yet... :rolleyes:
Keaton
I got the engine all togother for the most part, its about 10:00 at night so I stopped and I got it togother but was doing wiring:( sadily, but I need oil in the engine and wires and I should have a good k161, and now I am need to look how available a right side spindall top not shure the exact name. but I'll figure it out.
953 nut
I hope so.       :handgestures-fingerscrossed:  Keep us posted.
Keaton
it turns over good, and I was checking for spark, and the generator started going slower then my cheap Menards switch puffed some white smoke then got hot, I pulled it apart because it was the main starter switch. so I need to see what kind of switch to get is they still make a aftermarket one.
953 nut
Keaton
@953 nut I ordered a 12/24 volt push button switch off of amazon last night, I may get that when I patina restore it now I just want to get it running and someone put screws in the dash in place of the rivits and all 3 broke, they should not be hard I can get to the front and back of the bolt, thank you
