cumminscook 60 #1 Posted August 17 Hey guys just got a 523dxi temp lights is coming on coolant is good what do you guys think Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,070 #2 Posted August 17 What is your model number and serial number? Makes a difference. Share this post Link to post Share on other sites
cumminscook 60 #3 Posted August 17 it is a 1998 only have the model # 73550 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,070 #4 Posted August 18 Look through these 24 files. I was going to look for what the temp light is for but you can do that also. These files are in no particular order with this type of search https://www.wheelhorseforum.com/search/?q=73550&quick=1&type=downloads_file The 73550 is a 1998 model only but most model numbers where produced multiple years so the serial number is required. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,070 #6 Posted August 18 Added some color to the wiring but see I missed uploading it. Here it is Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,070 #7 Posted August 18 Item #8 on this page is the 99-9157 temperature switch but it is not illustrated Must be located around the water pump. $73.99 https://www.partstree.com/models/73550-523-dxi-toro-garden-tractor-sn-089000001-089999999-1998/engine-assembly-17/. Item #368 at B&S and cheaper $50.99 https://www.partstree.com/models/582447-0125-a1-briggs-stratton-horizontal-engine/water-pump-fan-23/ Top left corner. Share this post Link to post Share on other sites
