Sunny Burger 16 #1 Posted August 14 Hello, I broke my clutch spring on my 312-8. It is a spring-only system. Can someone tell me the location of the attachment point of the non-pedal end? Thanks. Share this post Link to post Share on other sites
ebinmaine 67,398 #2 Posted August 14 That's a Toro 108035 spring. It attaches to the web of the tranmission at the axle flange. Share this post Link to post Share on other sites
953 nut 55,164 #4 Posted August 14 Looks like Eric has your answer. If you need any other information please feel free to ask. 1 Share this post Link to post Share on other sites
Ed Kennell 38,114 #5 Posted August 14 I use my brake spring tool all the time to safely install and remove my Wheel Horse springs. https://www.northerntool.com/products/performance-tool-brake-spring-pliers-model-w175-9094100?cm_mmc=Bing-pla&utm_source=Bing_PLA&utm_medium=Automotive > Automotive Repair Tools > Brake Repair&utm_campaign=Performance Tool&utm_content=9094100&cmpid=53403372&agid=3200075881&tgtid=pla-4577473070981041&prdid=9094100&ogmap=SHP|PLA|BING|STND|c|SITEWIDE||Auto Repair - SC|Auto Repair - SC||53403372|3200075881&gclid=58b6137fbe771cabef8f75c321e336a0&gclsrc=3p.ds&msclkid=58b6137fbe771cabef8f75c321e336a0 2 Share this post Link to post Share on other sites
ebinmaine 67,398 #6 Posted August 14 1 minute ago, Ed Kennell said: brake spring tool all the time to safely install and remove my Wheel Horse springs. Excellent idea. I do the same. In fact I probably learned that from this site. 1 Share this post Link to post Share on other sites
peter lena 8,605 #7 Posted August 14 @Sunny Burger along with that spring , get some aerosil penetrant , like KNOCK R LOOSE , aerosol can , extension tube to make the related rust / movement areas , then a red grease spray , lube , clutch pedal set up , can / should work without effort , might look up related schematic drawing to show every , movement / connection point , pete Share this post Link to post Share on other sites
