Daniel_Heetderks 36 #1 Posted August 12, 2024 May be a stupid question, but does anyone know how to hammer these out? Found out most of the aftermarket flow-jet carbs come with one of the linkages connected backwards. I will need to hammer this out and flip it around. I just dont know how to get this thing out and replace it (I dont have any fancy tools, and I tried just hammering it out with a small nail and hammer). Share this post Link to post Share on other sites
Racinbob 12,424 #2 Posted August 13, 2024 You would be best off getting a set of roll pin punches and using the appropriate size to drive it out. A nail will likely damage it. 1 3 Share this post Link to post Share on other sites
ri702bill 10,571 #3 Posted August 13, 2024 Your old OE linkage MAY fit to replace the "offshore" part... Share this post Link to post Share on other sites
WHX?? 53,330 #4 Posted August 13, 2024 Odd ...all of the offshore Briggs leak jets I have gotten were throttle correct. Set of roll pin punches. There is no way you can (decently) maintain a horse without a set. Cheap set for hobbyist. 1 Share this post Link to post Share on other sites
8ntruck 8,332 #5 Posted August 13, 2024 You will want some solid back up to support the piece of linkage when you drive the pin out. 1 1 Share this post Link to post Share on other sites
lynnmor 8,254 #6 Posted August 13, 2024 1 hour ago, 8ntruck said: You will want some solid back up to support the piece of linkage when you drive the pin out. I would make up a punch and spacer for use in a small, but heavy duty, C-clamp. 1 Share this post Link to post Share on other sites
8ntruck 8,332 #7 Posted August 13, 2024 One of those bench top arrbor presses would do the job too. Share this post Link to post Share on other sites
wallfish 18,787 #8 Posted August 14, 2024 (edited) On 8/12/2024 at 7:49 PM, Daniel_Heetderks said: Found out most of the aftermarket flow-jet carbs come with one of the linkages connected backwards I'm no B&S expert and only worked on a few, but would it be easier to just correct the linkage? That stop and the screw appears like it may not work properly flipped. Maybe a pic of the whole thing and linkage not so close up Edited August 14, 2024 by wallfish Share this post Link to post Share on other sites
