peter lena 10,029 #1 Posted August 12, 2024 just had my 2 month lower spine check out , spot on , healing / working as it should , gaining everyday , also found right hip joint wear issue , that was increased with the spine issue , seeing dr soon on that , possible injection to settle it down , or same day replacement , to make it equal to lower back alignment , makes most sense , my results with this center has been very thorough in its , verification of issue , and correction of it . like the idea of same day hip socket replacement , inside of a week , you are good to go , for me walking without pain , would be wonderful , my father was loaded with arthritis , back in the butcher shop days, would not even think about it , had a ruptured appendix back in the 1920,s , the surgical work looked like it was done with a shovel , horrible . eliminate the issue , just my take on chronic , problem , pete 6 Share this post Link to post Share on other sites
953 nut 68,748 #2 Posted August 12, 2024 Glad you got it taken care of early enough to have a good outcome. 2 1 Share this post Link to post Share on other sites
peter lena 10,029 #3 Posted August 12, 2024 @953 nut thank you for that , back in the day , watched a number of macho men tough out a problem , the results were always the same , fear of dr,s and building on issues that killed them early , learned what not to do , eliminated the problem . today , regular dr check ups , is a no brainer , and its easy too , pete 3 Share this post Link to post Share on other sites
