hotajax 226 #1 Posted August 12, 2024 (edited) I know about Rotella and Kohler oil. Are there other brands out there? Plain old straight weight 30 oil. Not trying to turn this into a "best oil" discussion. Thanks. Edited August 12, 2024 by hotajax Share this post Link to post Share on other sites
ebinmaine 70,662 #2 Posted August 12, 2024 I use Kinetix because it's inexpensive, delivered to my place, and meets the criteria we need. If not for that I'd likely go to the above mentioned Rotella. 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,123 #3 Posted August 12, 2024 Pennzoil sells SAE 30 and tractor supply has there brand of it too. I use Rotella though. 3 1 Share this post Link to post Share on other sites
ri702bill 8,952 #4 Posted August 12, 2024 Yup - Rotella conventional oil, not synthetic. 2 Share this post Link to post Share on other sites
tunahead72 2,515 #5 Posted August 12, 2024 NAPA carries several brands: Their own brand, Valvoline, Pennzoil, Shell/Rotella, ..., whatever's your pleasure. 2 1 Share this post Link to post Share on other sites
953 nut 57,834 #6 Posted August 12, 2024 10 hours ago, Mike'sHorseBarn said: tractor supply has there brand Tractor Supply is the best as far as I'm concerned, auto parts stores don't carry much in straight 30 because cars don't use it, but tractors do. 2 Share this post Link to post Share on other sites
adsm08 2,633 #7 Posted August 13, 2024 Almost every brand of oil will have an SAE-30. There are only a few companies that bottle the stuff in the US. They just brand the bottles for the others. Share this post Link to post Share on other sites
Toby Stockman 88 #8 Posted August 13, 2024 (edited) I use Wolfs Head oil in all my tractors seems to be a western NY thing I also use there gear oil and red grease Edited August 13, 2024 by Toby Stockman 1 Share this post Link to post Share on other sites
hotajax 226 #9 Posted August 13, 2024 1 hour ago, adsm08 said: Almost every brand of oil will have an SAE-30. There are only a few companies that bottle the stuff in the US. They just brand the bottles for the others. I'm from eastern PA. Where is Dillsburg? Share this post Link to post Share on other sites
bds1984 1,466 #10 Posted August 13, 2024 12 hours ago, Toby Stockman said: I use Wolfs Head oil in all my tractors seems to be a western NY thing I also use there gear oil and red grease We have that here in Michigan, too. I've never used the 30W variety, but their 15W40 is great stuff. Many of us who use store brand oils (region dependent) are using Amalie bottled oils (Wolf's Head). Share this post Link to post Share on other sites
lynnmor 7,556 #11 Posted August 13, 2024 17 hours ago, 953 nut said: Tractor Supply is the best as far as I'm concerned, auto parts stores don't carry much in straight 30 because cars don't use it, but tractors do. TSC did have HD SAE 30 Traveller brand with a SJ rating, just right for our gasoline engines. I still have some, but the new flavor may be SN (description on the website is confusing), so you can pour it thru a catalytic converter and put it on your ice cream. They also have a diesel 30 weight oil if you don't care about having the oil rated for gasoline engines. Share this post Link to post Share on other sites
adsm08 2,633 #12 Posted August 13, 2024 22 hours ago, hotajax said: I'm from eastern PA. Where is Dillsburg? About halfway between Harrisburg and Gettysburg. Share this post Link to post Share on other sites
Artmilaca 23 #13 Posted August 14, 2024 On 8/12/2024 at 11:01 AM, tunahead72 said: NAPA carries several brands: Their own brand, Valvoline, Pennzoil, Shell/Rotella, ..., whatever's your pleasure. Napa's own brand is Valvoline or so I was told by the store manager 1 Share this post Link to post Share on other sites
ebinmaine 70,662 #14 Posted August 14, 2024 8 minutes ago, Artmilaca said: Napa's own brand is Valvoline or so I was told by the store manager One of our local Carquest stores was told his Fram oil is Amalie. Share this post Link to post Share on other sites
Brockport Bill 1,822 #15 Posted August 15, 2024 How about the Kohler oil with zinc additive designed for their older Kohler engines Share this post Link to post Share on other sites
RED-Z06 2,478 #16 Posted August 16, 2024 As long as its not "sae 30 non-detergent"...sae30 is not terribly common anymore, its disappearing like sae20 did, which used to be pretty easy to find. Sae30 does still come in diesel flavors in some stores, usually 2.5g jugs, its fine to use diesel oil in gas engines. Share this post Link to post Share on other sites
lynnmor 7,556 #17 Posted August 16, 2024 This article provides some information for those that want to experiment with using oils that aren't produced for their application. 1 Share this post Link to post Share on other sites
