Retired Wrencher 5,464 #1 Posted August 7 Like to take a poll on new plastic fuel pumps. Do you like or do you hate them. They just look cheap to me. Let me know what you think. Share this post Link to post Share on other sites
ri702bill 8,327 #2 Posted August 7 For the most part, thumbs DOWN. 2 Share this post Link to post Share on other sites
953 nut 55,290 #3 Posted August 7 I like things that work well and can be repaired as needed to keep them working. Therefore, I don't like plastic fuel pumps because they are throwaways. 3 Share this post Link to post Share on other sites
grinchsr 627 #4 Posted August 7 They are junk and can not be trusted to run for long. I had the pump arm break off on a couple. 2 Share this post Link to post Share on other sites
Treepep 564 #5 Posted August 7 I do keep el cheapo stuff like that around. Sometimes limping a horse out of the elements is worth it. Get it in, fix correctly, save junk plastic fuel pump for the next failure. (which may be the same junk pump) just a thought 1 Share this post Link to post Share on other sites
WHX?? 48,828 #6 Posted August 7 On the fence but do know order two and chances are one will work. What's a guy to do when metal ones are NLA? Electric I guess. 2 Share this post Link to post Share on other sites
peter lena 8,634 #7 Posted August 7 @Retired Wrencher have a couple of these in regular use ,https://www.amazon.com/CarBole-Universal-2-3-5P-S-I-Operating-Self-Priming/dp/B01IR6BNKY/ref=asc_df_B01IR6BNKY/?tag=hyprod- very solid , no issues at all , low pressure , monitors itself , added a single LED dash bulb . to verify operation ,would also clean out related tank , fresh fuel lines , in line filters , to eliminate chronic issues . also get a fuel pump block plate , for old pump removal . pete 1 Share this post Link to post Share on other sites
ebinmaine 67,569 #8 Posted August 7 2 hours ago, WHX?? said: On the fence but do know order two and chances are one will work. What's a guy to do when metal ones are NLA? Electric I guess. Or vacuum pulse. That's what I'm trying with my current build. 1 Share this post Link to post Share on other sites
ebinmaine 67,569 #9 Posted August 7 3 hours ago, Retired Wrencher said: Like to take a poll on new plastic fuel pumps. Do you like or do you hate them. They just look cheap to me. Let me know what you think. I'll rebuild metal pumps as long as I can get the parts. Even an OE Kohler fuel pump has been plastic for decades. Are they better than cheapos? Yeah probably but also HUGE money. 3 Share this post Link to post Share on other sites
pfrederi 17,741 #10 Posted August 7 47 minutes ago, ebinmaine said: Or vacuum pulse. That's what I'm trying with my current build. Failed vacuum pulse pumps can suck gas into the crank case just like a failed diaphragm in a cam operated pump. Why take the chance ...electric isn't that expensive... 2 Share this post Link to post Share on other sites
ebinmaine 67,569 #11 Posted August 7 7 minutes ago, pfrederi said: Failed vacuum pulse pumps can suck gas into the crank case just like a failed diaphragm in a cam operated pump. Why take the chance ...electric isn't that expensive... That was mentioned in my other thread too. And to use a shutoff. I HAVE shutoffs in all my tractors but I honestly don't remember to USE them often at all. I have 2 pulse pumps here and a Facet electric. I was going to save the electric pump for a different rig but I'm thinking I may be better off to use it. 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 2,998 #12 Posted August 7 I haven't had any luck with plastic pumps. I have one plastic one on my c161 that surprisingly works, but it was on there when I got it and it looks old. I always buy metal pumps when I can find them and keep them around and rebuild as needed. 2 Share this post Link to post Share on other sites
Retired Wrencher 5,464 #13 Posted August 7 1 hour ago, ebinmaine said: That was mentioned in my other thread too. And to use a shutoff. I HAVE shutoffs in all my tractors but I honestly don't remember to USE them often at all. I have 2 pulse pumps here and a Facet electric. I was going to save the electric pump for a different rig but I'm thinking I may be better off to use it. Eric is there a wiring diagram and these do work on Start /gen engines? 1 Share this post Link to post Share on other sites
pfrederi 17,741 #14 Posted August 7 9 minutes ago, Retired Wrencher said: Eric is there a wiring diagram and these do work on Start /gen engines? Just tap into the line going to the + on the coil. Yes they work on S/G 1 1 Share this post Link to post Share on other sites
Retired Wrencher 5,464 #15 Posted August 7 2 minutes ago, pfrederi said: Just tap into the line going to the + on the coil. Yes they work on S/G No Battery wires? Share this post Link to post Share on other sites
ebinmaine 67,569 #16 Posted August 7 3 minutes ago, Retired Wrencher said: No Battery wires? Electric fuel pump should have 2 wires. Normally, Red is hot. Black is ground. Run the red as stated above. Run the black right to the battery negative/ ground. 2 Share this post Link to post Share on other sites
pfrederi 17,741 #17 Posted August 7 (edited) The I terminal (coil + wire) is 12 volts in start and run. That and a ground wire is all you need. I ground mine to the pump mounting bolts haven't had any issues. Edited August 7 by pfrederi 2 Share this post Link to post Share on other sites
Retired Wrencher 5,464 #18 Posted August 7 (edited) 10 minutes ago, pfrederi said: The I terminal (coil + wire) is 12 volts in start and run. That and a ground wire is all you need. I ground mine to the pump mounting bolts haven't had any issues. Where did you get your pump. How does this mount up? On the old pump hole? Edited August 7 by Retired Wrencher Share this post Link to post Share on other sites
pfrederi 17,741 #19 Posted August 7 11 minutes ago, Retired Wrencher said: Where did you get your pump. How does this mount up? On the old pump hole? All my electric pumps are under the seat fuel tanks. Pumps push better than suck so I mount them next to the tank. I use Facet posiflo pumps now ..had a 50% failure rate on the cheapie China pumps../ You can leave the old pump in place cap the fuel line fittings... 4 Share this post Link to post Share on other sites
Retired Wrencher 5,464 #20 Posted August 7 (edited) 16 minutes ago, pfrederi said: All my electric pumps are under the seat fuel tanks. Pumps push better than suck so I mount them next to the tank. I use Facet posiflo pumps now ..had a 50% failure rate on the cheapie China pumps../ You can leave the old pump in place cap the fuel line fittings... So I guess I just tape in to the existing fuel line but with the 856 it will have to be a forward mount. Maybe off the coil bracket. Thanks for all your help. I will get this done. Eventually they will all have these as the old pumps wear out. Did you get this at EBay or other site. OHH Also is there a model number you use and good for 8hp to 12 hp that is what I have. Edited August 7 by Retired Wrencher Share this post Link to post Share on other sites
pfrederi 17,741 #21 Posted August 7 (edited) I have used Aircraft spruce as a source also you can use Amazon. I have been using the 1.5 - 4.0 PSI others prefer the 1-2 psi (since your tank is higher and closer 1-2psi should work fine) Facet pumps are made in USA Elmira NY Edited August 7 by pfrederi 1 1 Share this post Link to post Share on other sites
Handy Don 12,233 #22 Posted August 7 1 hour ago, Retired Wrencher said: So I guess I just tape in to the existing fuel line but with the 856 it will have to be a forward mount. The pump will need a solid mount so it doesn’t vibrate 1 Share this post Link to post Share on other sites
squonk 41,145 #23 Posted August 7 Unless you want " Original" to satisfy the OHHH and AHH guys, the judges at the WH " Concours D' Elegance " show or it's a recoil no battery tractor it makes no sense to put on an an old ready to warp and leak again metal pump. Go electric. 1 Share this post Link to post Share on other sites
Retired Wrencher 5,464 #25 Posted August 8 14 hours ago, Handy Don said: The pump will need a solid mount so it doesn’t vibrate Meant to say tap into the fuel line. Share this post Link to post Share on other sites
