Condor
AXLE SEAL REPLACEMENT
Condor
Difficulty in removing axle on sundstrand 90-1140  C160 for seal replacement any comments welcomed.
Also what lubricant for replacement.
ebinmaine
Removing the axle isn't necessary to change seals.
Can you post pics and describe what you've done so far?
Condor
I just purchased the seals for the hydro for the moment
Condor
Am I in the wrong forum? I thought I posted in transmissions axles
ebinmaine
Yep you did. No worries.
ebinmaine
The big thing on replacing seals will be removing the wheel hubs.
DO NOT USE A 3 JAW PULLER.
There are good threads on here about creating a good usable hub puller.
I'll be removing hubs today. I can post pics too.
ri702bill
Posted (edited)
Are you having difficulty removing the axle HUB?? The hub has to come off, the axle can stay put.
DO check for excessive play in the outer bearing - if it is bad, the Unidrive comes out and apart... at that point just replacing the seal is a waste of time & money...
Edited by ri702bill
ebinmaine
Click on the link below then scroll down a bit.
There's a few good pullers pictured.
ebinmaine
Just the regular oil is fine.
This is important.
The seals certainly can be aged and dry out.
However.... a common cause for a bad seal is a bad bearing.
ebinmaine
@Condor
Here's a few pics of the puller setup I use.
This is a home shop made piece. (Not my build).
These are 7/16-20  x 3" grade 8 bolts.
I put 7/16 lugnuts and washers on to help spread the pulling strain/pressure.
  • Like 4
Condor
All above information is very helpful, will do all evaluation on info provided thanks all!
stevasaurus
For oil replacment, you need to see what oil you have in there.  If your old oil is red, ATF.  If it is golden, 10W-30.  You want to use the same kind of oil that is in there.  :occasion-xmas:
ri702bill
Is that "weld" or rabbit droppings holding the nut in place??? I too can lay a bead with the worst of them....!! :laughing-rofl::o
adsm08
JB weld
  • Haha 1
ri702bill
At least it is in compression instead of tension. It just needs to stand up to the rotary force !! :lol:
ebinmaine
1 hour ago, ri702bill said:
Is that "weld"
That's a series of six large welds.
I'd bet it would pull a fair amount before I ever think of replacement.
oliver2-44
Posted (edited)
That’s a new one.  EB certainly brings out the “fertilizer” in these conversations
Of course. I don’t have any room to comment on the weld
“Burn them in hot and deep so it doesn’t matter what they look like on top”
Edited by oliver2-44
ebinmaine
And there not my welds.....
squonk
Posted (edited)
Comment on Eric's puller. If building your own puller, try to use fine thread on the force screw. It will pull slower with more pulling force. Kind of like low gear on a tractor.
Edited by squonk
  • Excellent 3
ebinmaine
Agreed.
That was discussed when I bought it.
This is the nut & bolt handy to the builder when it was put together. It's treated me well as is.
Given the strength of the setup I have now I'll likely be using it for years.
I'm known to be a tad bit rough on tools so  If I ever do break or damage the threads I'll go to a fine thread.
pfrederi
Make sure yo have drained the transmission before you try pulling the seal Yours is hydro and there are few qts of fluid that will come running out when you pull the seal...
