snowhound 106 #1 Posted August 1, 2024 My 417 has been an head ache since I got it, sometimes it would run OK but never great and not at all most of the time. Today I removed some of the covers so I had better access to the points, removed the points cleaned them, even though they looked good, and reinstalled and set the gap. I pulled the sparkplugs and found they weren't a pair, they were two different plugs so I replaced them with the correct plugs, started it and everything seemed fine. It ran smooth idled fine and when I opened the throttle it was smooth and steady. But, after putting the covers back on it wouldn't start it would fire a few times and die. I tried a little starting fluid and it did start but only after it cranked for awhile and died as soon as the fluid burned. I removed the plugs and put some gas in each plug hole and replaced the plugs and tried strating it but it only fired a couple of times after cranking for about 10 seconds. Any suggestions on what I should do next? Share this post Link to post Share on other sites
midpack 1,148 #2 Posted August 1, 2024 Have you tried turning it over with the fuel line disconnected from the carb (into a can) to see if the fuel pump is OK? I have a series 1 that I had to put electric on. I don't know if series 2 have that problem too Share this post Link to post Share on other sites
snowhound 106 #3 Posted August 1, 2024 I did check the fuel pump and it is working well Share this post Link to post Share on other sites
953 nut 68,520 #4 Posted August 1, 2024 1 hour ago, snowhound said: after putting the covers back on it wouldn't start it would fire a few times and die. Whenever a problem comes up the first p[lace to look is whatever was done just before the problem arose. Could be a wire got knocked loose or pinched by the sheet metal. Run a jumper wire from your battery "+" terminal to the ignition coil "+" terminal and see if the problem clears up. Share this post Link to post Share on other sites
oliver2-44 11,694 #5 Posted August 2, 2024 18 hours ago, 953 nut said: Whenever a problem comes up the first p[lace to look is whatever was done just before the problem arose. Could be a wire got knocked loose or pinched by the sheet metal. Run a jumper wire from your battery "+" terminal to the ignition coil "+" terminal and see if the problem clears up. Just a reminder, don't keep this jumper in place if you are not actively cranking or running the tractor. it could bur the points if left in place for a long time. (A few minutes as your working on it is fine) 1 Share this post Link to post Share on other sites
