rmaynard 15,434 #1 Posted August 1 I have a model 79350, 48" snow plow on my 1996 416-H. However, I've never noticed these keyhole type holes in the bottom reinforcement bar on the bottom of the backside of the blade until today. I am curious what they are for. 1 Share this post Link to post Share on other sites
ebinmaine 67,406 #2 Posted August 1 If there is a set like that near both ends of the plow, those are for mounting shoes or plow feet if you like. 3 Share this post Link to post Share on other sites
c-series don 8,687 #3 Posted August 1 I agree with Eric, but other than the old style mushroom skids I haven’t seen factory ones that bolt in there? 1 Share this post Link to post Share on other sites
ebinmaine 67,406 #4 Posted August 1 2 minutes ago, c-series don said: I agree with Eric, but other than the old style mushroom skids I haven’t seen factory ones that bolt in there? I don't exactly know how the originals were set up. I have a set that was made by a fellow hillbilly from down in wv. I can show pictures of how those might go on. 1 Share this post Link to post Share on other sites
c-series don 8,687 #5 Posted August 1 I understand that carriage bolts would slid in the holes but again I haven’t seen any from the factory. That being said, now someone will probably post a picture!! 2 1 Share this post Link to post Share on other sites
ebinmaine 67,406 #6 Posted August 1 @gwest_ca any info? Share this post Link to post Share on other sites
rmaynard 15,434 #7 Posted August 1 Nothing is shown in the parts book. Share this post Link to post Share on other sites
ri702bill 8,313 #8 Posted August 1 2 hours ago, ebinmaine said: If there is a set like that near both ends of the plow, those are for mounting shoes or plow feet if you like. Yup...I got a set with my 79350 plow, but welded 3/8" thick wear pads to the undersides. IF noone else posts a pocture of the OE ones, I can post one a bit later of mine... Share this post Link to post Share on other sites
rjg854 11,358 #9 Posted August 1 21 minutes ago, ri702bill said: . IF noone else posts a picture of the OE ones, I can post one a bit later of mine... 3 Share this post Link to post Share on other sites
ebinmaine 67,406 #10 Posted August 1 Here's the aftermarket set I have. The part that touches the ground is 3" x 4" They're made of a hunk of 4 x 6 rectangle tube steel cut at the corners and heated and bent to the angle. Share this post Link to post Share on other sites
Handy Don 12,209 #11 Posted August 1 Following in hopes that someone will have a picture of a factory-made set! 2 Share this post Link to post Share on other sites
rmaynard 15,434 #12 Posted August 1 55 minutes ago, ri702bill said: . If no one else posts a picture of the OE ones, I can post one a bit later of mine... Please do Bill 1 Share this post Link to post Share on other sites
lynnmor 7,303 #13 Posted August 1 This might help: https://www.partstree.com/models/92-6840-toro-skid-kit/ 3 2 Share this post Link to post Share on other sites
ebinmaine 67,406 #14 Posted August 1 Just now, lynnmor said: This might help: https://www.partstree.com/models/92-6840-toro-skid-kit/ Yes! Share this post Link to post Share on other sites
ri702bill 8,313 #15 Posted August 1 18 minutes ago, lynnmor said: This might help: https://www.partstree.com/models/92-6840-toro-skid-kit/ The drawing is a bit washed out, but them's them... Share this post Link to post Share on other sites
rmaynard 15,434 #16 Posted August 1 Only difference is my slots go horizontal, those are vertical, but that appears to be the answer. Thanks 1 Share this post Link to post Share on other sites
8ntruck 6,998 #17 Posted August 2 When the Toro on line parts list was operating, I found a listing for the feet, saying they were still available. A trip to my local Toro dealer turned up a price of something like $70 each. I think that's a bit steep for what is essentially a bracket. Then again, they might be made out of a heat treated high carbon steel for wear resistance. Share this post Link to post Share on other sites
Handy Don 12,209 #18 Posted August 2 2 hours ago, rmaynard said: Only difference is my slots go horizontal, those are vertical, but that appears to be the answer. Thanks Slots for adjusting are more likely in the skid than on the blade. I’d take the parts tree image with a grain of salt. Share this post Link to post Share on other sites
peter lena 8,606 #19 Posted August 2 @rmaynard https://www.google.com/search?q=quad++atv+snow+plow+skids&sca_esv=9267af3241730e66&rlz=1C1CHBF_enUS866US866&ei=p96sZsSiKcWcptQPksbC4Qw& never stop an issue with one stop idea , those quads have an amazing amount of stuff , carriage bolting on a slide point / bracket , is simple easy , would also , use the spring enhanced set up , for blade float / ease . nothing sarcastic implied , , pete Share this post Link to post Share on other sites
ri702bill 8,313 #20 Posted August 2 17 hours ago, rmaynard said: Please do Bill Went to the garage to do so, but .... Plow moldboard is buried in the far corner with the skids not visable. Murphy's Law I guess... Murphy was a pessimist. Share this post Link to post Share on other sites
pfrederi 17,701 #21 Posted August 4 Official $70 skids 2 Share this post Link to post Share on other sites
rmaynard 15,434 #22 Posted August 4 2 hours ago, pfrederi said: Official $70 skids Cool. Thanks for the picture. 1 Share this post Link to post Share on other sites
Keaton 434 #23 Posted August 4 we have something like this on our skid loader so it does not destroy our gravel driveway Share this post Link to post Share on other sites
pfrederi 17,701 #24 Posted August 4 They work okay with the blade at 90 degrees angle it and they tend to dig in.... 1 Share this post Link to post Share on other sites
ebinmaine 67,406 #25 Posted August 4 21 minutes ago, pfrederi said: They work okay with the blade at 90 degrees angle it and they tend to dig in.... Yep. I tried a set last winter. Good idea. Poor execution. I figured round feet would be better but not so. Perhaps I need to go larger diameter? Next winter I'd like to try a 48" wide "scoop". That would be facing forward all the time so feet would work better. Share this post Link to post Share on other sites
