Sailman 1,291 #26 Posted August 5 (edited) 5 minutes ago, squonk said: Also condenser to coil negative. Can I have the condenser connected at the points with the coil negative wire or does it need to be at the coil? Also, when I go the battery route I move the spark plug wire to the coil? Should I remove the magneto? Edited August 5 by Sailman Share this post Link to post Share on other sites
squonk 41,060 #27 Posted August 5 49 minutes ago, Sailman said: Can I have the condenser connected at the points with the coil negative wire or does it need to be at the coil? Also, when I go the battery route I move the spark plug wire to the coil? Should I remove the magneto? Condenser can connect at the points. You will need a different spark plug wire that will connect to the new coil. Magneto can stay along for the ride. 1 1 Share this post Link to post Share on other sites
