Sailman
I fought the K161...and the K161 won.
Sailman
Posted (edited)
5 minutes ago, squonk said:
Also condenser to coil negative.
Can I have the condenser connected at the points with the coil negative wire or does it need to be at the coil?
Also, when I go the battery route I move the spark plug wire to the coil? Should I remove the magneto?
Edited by Sailman
squonk
Condenser can connect at the points. You will need a different spark plug wire that will connect to the new coil. Magneto can stay along for the ride.
