Mike'sHorseBarn 3,367 #1 Posted July 25, 2024 (edited) I have a head gasket on a k341 that refuses to stop leaking. I've had the head off and "planed" it on my piece of granite counter tip like I've done with many other heads. Has a new head gasket. I had the head off twice and tired a different gasket. Bolts are torqued to 30 ft lbs. I honestly don't know what else could be wrong. Any ideas or am I searching for a new head? Also I purchased this tractor at auction so I don't know it's history, but from what I can tell I guarantee this thing was run hot. I put a new exhaust valve in it to replace the burnt one that was in it. Edited July 25, 2024 by Mike'sHorseBarn 3 Share this post Link to post Share on other sites
oliver2-44 11,062 #2 Posted July 25, 2024 What does the top of the cast iro cylinder look like? Ck this. Bolt the head on lightly snug with no head gasket. Go around with feeler gages and mark any gaps. (You could also use some machinery Blue). Now torq the head down and recheck your gaps. This should show you any trouble areas of the block surface. Any pitted areas? 8 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,367 #3 Posted July 25, 2024 Top of the cast iron cylinder looks normal. No pits or anything. I'll have to bolt the head on with no gasket and check for gaps. 3 Share this post Link to post Share on other sites
RED-Z06 2,690 #4 Posted July 25, 2024 361s were picky with the ohv head, had to use a kohler gasket, and copper sealer on both sides, lube the head bolts and torque in sequence, warm up, then retorque...never had one blow twice. Edit- looks like a flathead in the pictures, 341? 1 Share this post Link to post Share on other sites
ri702bill 10,570 #5 Posted July 25, 2024 6 hours ago, RED-Z06 said: lube the head bolts and torque in sequence, warm up, then retorque. Chase the threads - by hand - in the block and wire wheel the head bolts. As I recall, there are hardened washers required under the hexheads on 3 of the bolts on large block Kohlers. Per the manual, torque the head in 10 ft/lb increments until reaching 30 ft/lbs and do one more pass. Use a genuine Kohler head gasket that has the metal "fire ring" on the inside. Doing this helps prevent the compression blowing out the gasket, by necessitates retorquing - in the proper sequence cold several times. A cast iron block, aluminum head, steel head bolts and the gasket - all different materials that heat and expand at different rates. Curious - did it seem too easy to unscrew the bolts with the bad gasket??? If so, they were not properly torqued....... KohlerKseriesManual.pdf 1 Share this post Link to post Share on other sites
squonk 44,860 #6 Posted July 25, 2024 New flange head bolts may help as well. 2 1 Share this post Link to post Share on other sites
953 nut 63,003 #7 Posted July 25, 2024 Mike, did you warm the engine up and then retorque the head after it cools down? Has the gasket blown out at the same point both times? You could check the block surface by using some Prussian Blue (or a good old magic marker) on the mating surface of the block and adhere some sandpaper to your granite and gently sand the color away seeing if there is a low spot. 2 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,367 #8 Posted July 25, 2024 8 hours ago, RED-Z06 said: 361s were picky with the ohv head, had to use a kohler gasket, and copper sealer on both sides, lube the head bolts and torque in sequence, warm up, then retorque...never had one blow twice. Edit- looks like a flathead in the pictures, 341? It is a 341. My fat fingers typed 6 lol Share this post Link to post Share on other sites
Mike'sHorseBarn 3,367 #9 Posted July 25, 2024 2 hours ago, ri702bill said: Chase the threads - by hand - in the block and wire wheel the head bolts. As I recall, there are hardened washers required under the hexheads on 3 of the bolts on large block Kohlers. Per the manual, torque the head in 10 ft/lb increments until reaching 30 ft/lbs and do one more pass. Use a genuine Kohler head gasket that has the metal "fire ring" on the inside. Doing this helps prevent the compression blowing out the gasket, by necessitates retorquing - in the proper sequence cold several times. A cast iron block, aluminum head, steel head bolts and the gasket - all different materials that heat and expand at different rates. Curious - did it seem too easy to unscrew the bolts with the bad gasket??? If so, they were not properly torqued....... KohlerKseriesManual.pdf 14.16 MB · 1 download It was definitely too easy to unbolt the head the first time. I'll try this sequence and see what happens. 2 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,367 #10 Posted July 25, 2024 21 minutes ago, 953 nut said: Mike, did you warm the engine up and then retorque the head after it cools down? Has the gasket blown out at the same point both times? You could check the block surface by using some Prussian Blue (or a good old magic marker) on the mating surface of the block and adhere some sandpaper to your granite and gently sand the color away seeing if there is a low spot. These are new spots from when I first took it off. I had put sandpaper on my granite and you could definitely see that the head was warped. I sanded and sanded until I got it flat. 1 2 Share this post Link to post Share on other sites
Keaton 466 #11 Posted July 26, 2024 im, no expert on this by any means, but what about a thick copper head gasket, or do they make those anymore, or are they available, I would stack mabye 2 dpepending on the thickness, again I'm not every experienced compared to any of you either 1 Share this post Link to post Share on other sites
Keaton 466 #12 Posted July 26, 2024 23 hours ago, RED-Z06 said: and copper sealer on both sides that also would do it I'm guessing because copper should show you the problem 1 Share this post Link to post Share on other sites
953 nut 63,003 #13 Posted July 26, 2024 22 hours ago, Mike'sHorseBarn said: I had put sandpaper on my granite and you could definitely see that the head was warped. How about the engine block? You did say it had been run hot before you got it, could be some deformation of the mating surface of the block. 1 Share this post Link to post Share on other sites
squonk 44,860 #14 Posted July 26, 2024 1 hour ago, 953 nut said: How about the engine block? You did say it had been run hot before you got it, could be some deformation of the mating surface of the block. I agree. That leak is right at the exhaust area 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,367 #15 Posted July 26, 2024 I'm thinking of trying some copper gasket spray. I just want to get it through until it comes time to fix it up. It could very well be that the mating surface is warped. When I paint this one, I'll tear the engine down and get everything planed 1 1 Share this post Link to post Share on other sites
Joe Shmo 158 #16 Posted July 27, 2024 That second picture sure looks like it has a huge gap in the head. Share this post Link to post Share on other sites
sqrlgtr 1,328 #17 Posted July 27, 2024 13 hours ago, Joe Shmo said: That second picture sure looks like it has a huge gap in the head. Agree looks like a big gap, If it was me, I would be looking for another head. Looks like time you got that one flat there might be clearance issues. Just my though.. Share this post Link to post Share on other sites
Mike'sHorseBarn 3,367 #18 Posted July 27, 2024 So I messed with this this morning. I have gaps as big as .006 with the head laid on the bare block, no gasket and the heads been planed. So the mating surface has to be warped. I have a pretty good gouge in the bore as well. This engine will definitely need a total rebuild bu I put a gasket on with copper spray on it to see if I can keep it sealed until thay day comes. I have too many other irons in the fire to send an engine off for a $1,000 rebuild. It'll have to wait a year or two. 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,367 #19 Posted July 27, 2024 Update: that didn't work either, just blew out the sealer. 1 Share this post Link to post Share on other sites
RED-Z06 2,690 #20 Posted July 27, 2024 38 minutes ago, Mike'sHorseBarn said: Update: that didn't work either, just blew out the sealer. Might try the planing again, periodically turn the head for even pressure. Share this post Link to post Share on other sites
lynnmor 8,254 #21 Posted July 27, 2024 17 minutes ago, RED-Z06 said: Might try the planing again, periodically turn the head for even pressure. We still don’t know if the head is warped or the block needs flattened. Share this post Link to post Share on other sites
RED-Z06 2,690 #22 Posted July 27, 2024 9 minutes ago, lynnmor said: We still don’t know if the head is warped or the block needs flattened. A warped deck is definitely possible but usually the thinner aluminum part will warp before the much thicker cast iron. Ive had K/M heads so warped they split during torquing. Share this post Link to post Share on other sites
ranger 1,830 #23 Posted July 27, 2024 One thing that I’ve done before with warped pressure washer heads is to carefully’press’ them back into a semblance of flatness using a hydraulic press. If you have a decent gas torch, you could try loosely fitting the head to the block, without a gasket. Then gently heat the whole of the head with the torch, and tighten the head bolts fully. Keeping the head nice and hot for a few minutes afterwards. After it cools right down, it may then be ‘flatter’, and need less ‘planing’ to get a seal? Providing of course, the block is not distorted? The idea of thicker, or fitting two gaskets is not usually a good idea, it can cause more distortion! 1 Share this post Link to post Share on other sites
lynnmor 8,254 #24 Posted July 28, 2024 1 hour ago, RED-Z06 said: A warped deck is definitely possible but usually the thinner aluminum part will warp before the much thicker cast iron. Ive had K/M heads so warped they split during torquing. In post #18 he basically said it was the block, but apparently nothing was done. Share this post Link to post Share on other sites
RED-Z06 2,690 #25 Posted July 28, 2024 43 minutes ago, lynnmor said: In post #18 he basically said it was the block, but apparently nothing was done. Assuming the head is planed flat, doesn't take alot to shadetree plane a head uneven. I wish i had access to a bridgeport, ive got 3 or 4 heads that need it but are holding for now. Share this post Link to post Share on other sites
