ebinmaine
Hydro lift valve rebuild instructions?
ebinmaine
1984 Workhorse GT1800 hydro lift valve needs O-rings.
Anything we need to know about disassembly?
How to?
What NOT to do?
Thanks!
lynnmor
Posted (edited)
There is a screw in the back, remove it and out comes the spool, simple as it gets.  Replace the o-rings on the hose connections, if it has them, while it is out.
Edited by lynnmor
Handy Don
Posted (edited)
Under the acorn nut is the pressure relief valve. No need to mess with that unless there’s a known issue. Recalibrating it requires a hydro pressure gauge and some plumbing bits!
Edited by Handy Don
ebinmaine
Getting 4 new hoses installed.
All have new Orings.
:handgestures-thumbupright:
gwest_ca
ri702bill
O-ring material??? Buna-N may have been the original, better to replace with either Viton or HNBR.....
gwest_ca
An older service manual than the one above.
c-series don
@ebinmaine I recently rebuilt the same exact valve with no manual. I purchased a rebuild kit many years ago and finally got around to using it. It’s very simple, just take it apart on a clean surface. The hardest part is getting the valve in and out of the tractor. I loosely threaded in the hydraulic hoses and then bolted it to the tractor. I have the part number for the rebuild kit if you need it.
oliver2-44
Posted (edited)
On reassembly coat the O-Rings with a lite film of grease to help the spool slide through the housing.
Edited by oliver2-44
  • Like 4
