ebinmaine
Glue/cement for brake shoes?
ebinmaine
We've been using clear silicone for years.
Usually works OK.
We've had two fail over that time.
What's a good alternative chemical?
@rmaynard ?
oliver2-44
I've used JB Weld, no failures so far!
squonk
Goop adhesive, Gorilla Glue.
PWL216
Goop all-purpose. You’ll need about 1/2 oz.
Edited by PWL216
  • Like 4
squonk
Scuff up the band where the lining attaches. Gives the glue something to bite on.
ebinmaine
Ours are always down to bare metal.
I like the Goop idea. We may have some Gorilla glue around.
rmaynard
Usually works OK.
@rmaynard ?
The only way that you will have a failure is to improperly clean both surfaces or fail to allow ample time for curing.
Having said that, some are reporting to me that original Gorilla glue (urethane glue) works well, but requires dampening the surface and clamping well (Gorilla glue expands as it cures).
You might want to contact Brian Badman @76c12091520h and see what he uses to assemble his complete brake bands.
Edited by rmaynard
rjg854
:text-yeahthat: no problems so far
wallfish
File sand or grind some on it to roughen the surface which will give a better grip than a completely smooth surface
