ebinmaine 70,300 #1 Posted July 21, 2024 We've been using clear silicone for years. Usually works OK. We've had two fail over that time. What's a good alternative chemical? @rmaynard ? Share this post Link to post Share on other sites
oliver2-44 10,236 #2 Posted July 21, 2024 I've used JB Weld, no failures so far! 3 Share this post Link to post Share on other sites
squonk 42,274 #3 Posted July 21, 2024 Goop adhesive, Gorilla Glue. 3 Share this post Link to post Share on other sites
PWL216 905 #4 Posted July 21, 2024 (edited) Goop all-purpose. You’ll need about 1/2 oz. Edited July 21, 2024 by PWL216 4 Share this post Link to post Share on other sites
squonk 42,274 #5 Posted July 21, 2024 Scuff up the band where the lining attaches. Gives the glue something to bite on. Share this post Link to post Share on other sites
ebinmaine 70,300 #6 Posted July 21, 2024 51 minutes ago, squonk said: Scuff up the band where the lining attaches. Gives the glue something to bite on. Ours are always down to bare metal. I like the Goop idea. We may have some Gorilla glue around. Share this post Link to post Share on other sites
rmaynard 15,887 #7 Posted July 22, 2024 (edited) 3 hours ago, ebinmaine said: We've been using clear silicone for years. Usually works OK. We've had two fail over that time. What's a good alternative chemical? @rmaynard ? The only way that you will have a failure is to improperly clean both surfaces or fail to allow ample time for curing. Having said that, some are reporting to me that original Gorilla glue (urethane glue) works well, but requires dampening the surface and clamping well (Gorilla glue expands as it cures). You might want to contact Brian Badman @76c12091520h and see what he uses to assemble his complete brake bands. Edited July 22, 2024 by rmaynard 1 Share this post Link to post Share on other sites
rjg854 11,840 #8 Posted July 22, 2024 3 hours ago, squonk said: Goop adhesive, Gorilla Glue. no problems so far 1 Share this post Link to post Share on other sites
wallfish 17,383 #9 Posted July 22, 2024 1 hour ago, ebinmaine said: Ours are always down to bare metal. File sand or grind some on it to roughen the surface which will give a better grip than a completely smooth surface 1 Share this post Link to post Share on other sites
