squonk 41,104 #1 Posted July 21 (edited) I bought a 551 Suburban with no engine. It came with a belt guard. 551's came with a Tecky which is a big nay- nay here at The Wheel Horse Plaza / Fake Chicken and Tweety Bird Ranch. Got a K90 from @formariz but it's different enough that the belt guard wouldn't work. Maybe if I slotted the frame and moved the engine back farther. But I hated the belt slap noise the RJ's and Suburbans have when releasing the clutch. Plus @wallfish did such a yeoman's job in the blistering heat crafting some wire guides I wanted to keep them. So it was time to make a belt guard. I found a belt guard in my basement years ago. I have no idea where it came from or for what it was. It looked pretty crappy. Somebody in NC needed a guard so I gave it to Richard @953 nut to bring to NC from the show. Well that meet up never happened. Richard gave me the guard back this year. I thought great, More scrap! I got thinking of making a guard. This crappy looking guard metal was pretty stout and I'm no metal smith. So let's have at it. Using the belt guard I got with the tractor I sized how much I needed to cut out. Made lots of noise and cut the guard with my 4" grinder with a cutting blade. I put a dab of grease on the crankshaft to locate the approximate location of the hole needed. Using my very large Horror Fright compass I located the distance from the center of the crank to the rear mounting stud for the guard and drew an arc on the guard. A dab of grease on the stud and the rear stud location is approximated. I used the same procedure to locate the front mounting hole. Test fit the guard. It fit but it looked like it needed something. After consulting with Bear's @ebinmaine and backyard hammer mechanics we decided on rounding off the front. I also decided to round the rear some. Enclosing the edge would take some welding so I had to take it to my friend Bill the welder. He discovered this guard was galvanized. Never knew WH did this. He got it done the next day and I trial fitted the guard Prepped ,painted and installed. Edited July 21 by squonk 3 11 Share this post Link to post Share on other sites
Moparfanforever 844 #3 Posted July 21 Looks good from here!!! 1 Share this post Link to post Share on other sites
ebinmaine 67,484 #4 Posted July 21 Man that looks great Mike! 1 Share this post Link to post Share on other sites
wallfish 16,996 #5 Posted July 22 Grasshopper, You just graduated to yellow belt front yard hammer mechanic! LOL 1 7 Share this post Link to post Share on other sites
squonk 41,104 #7 Posted July 22 4 minutes ago, Pullstart said: Nice work! " Blue Hairs" 3 1 Share this post Link to post Share on other sites
squonk 41,104 #8 Posted July 22 Also " Losing Hairs " 3 1 Share this post Link to post Share on other sites
Handy Don 12,217 #9 Posted July 22 3 hours ago, squonk said: Also " Losing Hairs " Now THERE is a tangent just begging for comments! 4 Share this post Link to post Share on other sites
Tractorhead 9,064 #10 Posted July 25 Great Work Mike ! 👍 Regards from the „Haircompatible“ bavarian 😎😂 3 Share this post Link to post Share on other sites
oliver2-44 9,746 #11 Posted July 25 On 7/22/2024 at 5:18 AM, squonk said: Also " Losing Hairs " Not just Hairs Share this post Link to post Share on other sites
