Sodaking27
Front wheel bearing help
Sodaking27
I have a little update on the bearings. I reached out to another old WH dealer yesterday and the guy working in the parts was the guy I bought my first new WH (1987 310-8) from (Mark Lawson). He knew exactly what I was looking for. Mark reached out to Toro and got the info on who made the bearings for these upgrade kits. He was able to cross reference the number to a current bearing being made. He ordered 4 and hopefully they are the ticket. As soon as they come in and verify fit. I will post all the info.
Edited by Sodaking27
  • Like 5
Sodaking27
We have a winner. The bearing replacement for the Toro 107124 is Oregon 45-064.
Now to find some 2” black dust caps.
Bill D
Excellent find.
pfrederi
Curious... Oregon probably didn't make the bearing...any markings on it like a standard bearing #  Still about a C note to do both front wheels...
Sodaking27
I didn’t see any numbers on the bearings. Yes just about a C note for the four. 19.48 each.
peter lena
@JoeM  agree on your bearing , also for me , its the wide rubber side shields , that make a removal , clean out / re grease , with a hi/ temp / stress grease , that  makes those bearings live . since doing that and adding shim / washers to side slam , shucking , elimination , have had  no wheel issues at all . the correct lube also is nothing like the , "  lubricant " in there , another failure spot eliminated . also have HEIM steering joint ends , no failures , pete
