23 Reo
24x12-12
23 Reo
Are 24x12-12 rear tires too big for a 520H?
Pullstart
Stock?  Most likely.  You may be able to raise the fender however.
These are 24x12-12s on my 520Xi for reference.
ebinmaine
Depends on the brand of tire and actual measurements.
sqrlgtr
:text-yeahthat:
Sparky
  The width of the rear wheel will also affect the tires overall height…narrower wheel means a taller tire once it’s inflated.
  I think most 520’s have the wider wheels, not sure about the 1988-1989 models though.
clueless
:text-yeahthat:Why do you want the wider tires, for looks?
pfrederi
That is the tire size WH used on many D series... they were mounted on 10.5" wide rims     C series 7.5"  some 520s 8.5"
23 Reo
Posted (edited)
I just thought they would look good on my  97. I always put bias ply G60s or G50s on the back wheels of my cars in the 70's. Do you think I would be better off staying with the stock size?
Edited by 23 Reo
ebinmaine
IMHO that depends on your opinion and the desired task of the tractor.
Your opinion... because it's an aesthetic issue.
Personally I like big wide rear tires.
Desired task because wide tires do well on loose aggregate or mud but not great for snow.
23 Reo
Thanks Eric, I have dedicated plow tires with chains and wheel weights. Looks like I' m getting the fatties.
  • Excellent 2
ebinmaine
Pictures to follow???
Thor27
24x12-12 airlock. This was a 520 under the black hood & kohler.20230624_175131.jpg.3a96b28d66e12fa6b40f2c840701a406.jpg20230624_175255.thumb.jpg.e2fa5d1c222aac3fcddd170e66790f20.jpg
  • Excellent 3
Thor27
Those are on a 10" rim, they were hard to stretch that wide, they would be easier to mount on 8.5"s.
Thor27
Didn't the Ds with 12s use 26x12-12?
JoeM
Put a set of 24 12 12 on 10 inch rims, The rims had a little deeper back-set unlike the shallow ones WH used and I had to put spacers on so the tire did not contact the hydro brake.
C141 plenty of room under the fender tho.
I would be concerned if using a mower,. gauge wheels might hit the tires.
this one is for looking and not cooking.
  • Excellent 5
Pullstart
Good point.  I think my Xi has 26’s as well!
Monstrosity
Posted (edited)
These are 28X12 on 10.5 rims but I made them fit with gt14 rear tins. No spacer and they clear the trailer hitch mount.20240623_152442.jpg.a438abc03937febc845a7d6701ae0779.jpg20230819_170637.jpg.16068e7e3883ac430963f68c15209e12.jpg20230415_122547.jpg.99a0fda99b885143d32e50b514c42f4c.jpg
Edited by Monstrosity
  • Excellent 2
ebinmaine
Interesting color!
Any more pics around?
JoeM
1541493813_April20242.jpg.09060185f5831d6db0f995123efdfecf.jpg2001796460_April20245.jpg.4ed5bf4b8a04dde0318a10a1edcb644e.jpg
  • Excellent 3
