squonk
Opinions please Gentlemen
squonk
Posted (edited)
The belt guard I got with my 551 Suburban doesn't fit over the pulleys. This tractor originally came with a Tecky 5.5 rowboat anchor and the 2 piece transmission. I got it with no engine:rolleyes: and acquired a Non WH spec K90 from @formariz at the show. This K90 is shorter than the original Chief but as far as I can tell the pulleys are all the original size.
So I'm building a belt guard. I am no metal smith and am limited on the available toolage. I'm making it out of another belt guard that has seen better days. I have it rough finished on the tractor. Outside of of course painting it, I want to make it look a little better. Maybe square off the front? Cut the angle back farther? Round off the front? What do you think? I though about placing the original style guard over the replacement and tracing the patter only bigger but I will lose the side pieces of the guard that cover the belt. The metal is pretty thick and I have no way to bend it.
250956528_guardon.jpg.ed0bd3db27f2780786d27899f7c4197b.jpg1873324402_guardon.jpg.a1e2a99ddb86572f39f86af2234ef74e.jpg
Edited by squonk
  • Like 5
ebinmaine
Seems like roundererer would be more matcherizing to the roundhood lines but I'm not sure I like what I drew....
1823869626_Screenshot_20240716_175056_Chrome2.jpg.1d63243c0224edadde1d653f26f67c19.jpg
Maybe less aggressive curves than that?
Then close the front somehow?
wallfish
Posted (edited)
Are the pulleys too big? Or the distance between them is too far? Or ???
It will always look better if you can get that original guard to fit. Slotting engine mounting holes will not affect the value of the tractor.
Edited by wallfish
squonk
I thought of something like that. I have a friend who can tig a section over to cover the front.
wallfish
If you keep that guard I'd curve it like EB pictured. But also leave the 90 deg angled pieces in place and they can then be bent and curved around to close off the front.
Tack weld or braze it
squonk
Distance is too far. The pulleys are correct and the engine is as far back with the factory frame holes. One thing I want to avoid is the rattle these tractors have releasing the clutch when the belt slaps the guard. I had an RJ and this noise drove me nuts. The wire belt guides are working well and want to leave them on.
wallfish
1823869626_Screenshot_20240716_175056_Chrome2.jpg.1d63243c0224edadde1d653f26f67c19.jpg.7e69e942a6a468bb4226eff76282810f.jpg
squonk
I have the remnants of the guard I cut up that I believe has enough of the bent edge to run a continuous piece around the front.
If I do that I lose the front mounting hole
wallfish
Don't cut the complete circle just the front half. I can't make 1/2 circles
Full piece or just use the 2 on there and there will be a seem. One seem in the front by using the pieces on the guard.
Leave the bent curve too on whatever you do and it matches the rest of it.
squonk
Posted (edited)
Ok I gotcha. I'm going to take it to my buddy with these pictures. He has band saws ,plasma cutters, mig and tight welders ect.
Edited by squonk
wallfish
Mark the engine pulley location and size the best you can. He should be able to fix you right up
