TJN
Kohler engine gaskets
TJN
Hey guys/gals, I priced some small engine gaskets today ie. Air Cleaner to block, carb to block, fuel pump to block and fuel pump "center" gaskets.  Two each, except for four "center" pump ones.  The vendor called the supplier, then me with an $85.00+ cost!  Where do you get your gaskets and what do you think of "my" prices?  Thanks, Tom (TJN)
Toby Stockman
isavetractors.com has complete gasket sets for much cheaper
TJN
Toby, thanks for the info! I bought a cheap plastic replacement and it works fine.  Supprised the hell out of me. I also bought a rebuild kit to replace the diapharm (gasket) which was leaking in the original metal pump.  Waiting on delivery.  Thanks again, Tom
