mike avad 41 #1 Posted July 5 I have a 1976 wheelhorse B-80 with a 8hp Kohler engine, Will a 12HP engine off a 1970 Raider12 fit my B-80 wheel horse? Share this post Link to post Share on other sites
Sparky-(Admin) 21,315 #2 Posted July 5 Yep, it’ll fit and clear the hood. 1 Share this post Link to post Share on other sites
Lee1977 6,659 #3 Posted July 5 The holes to bolt the 12 on are already there. Does the Raider have a manual PTO? Share this post Link to post Share on other sites
mike avad 41 #4 Posted July 5 yes it dose have manual pto Share this post Link to post Share on other sites
ebinmaine 67,484 #5 Posted July 6 Is the belt guard from the 8 HP the same as the 12 HP? Share this post Link to post Share on other sites
Racinbob 11,077 #6 Posted July 6 11 hours ago, mike avad said: I have a 1976 wheelhorse B-80 with a 8hp Kohler engine, Will a 12HP engine off a 1970 Raider12 fit my B-80 wheel horse? Here's my 1976 B-80 with a K-341 16hp. It's a simple swap as the 76 and 77 B's were basically the same as the C's. As far as the PTO goes you'll need to swap the bearing race for the 1.125" shaft. The spring is different but will work fine. The engine bracket is different but easily modified. Other than that it will fit seamlessly. The frame, transmission, sheetmetal, etc. are identical. All the K-Series Kohler big blocks hang over on the right side making a lot of folks think it's too big but actually it's normal. On the Wheel Horse spec oil pan there's two threaded holes where a bolt runs into from under the frame. I think most of them have the holes. The 341 I used was purchased from WW Grainger new and it had them. I've heard some people use J bolts instead but I've never seen that. 3 Share this post Link to post Share on other sites
peter lena 8,625 #7 Posted July 6 @mike avad would take advantage of the manual PTO , very simple / easy improve at every " movement point " basically eliminate all the sloppy play , washers are good , like teflon washers at start / finish of anugging up , silicone spray grease . you can also add a HEIM JOINT to the forward end of the lever rod , like a fine thread DIE NUT , AEROSOL LUBRICATED , to over cut coarse threading , HEIM screws right on . made a point of making original intension , much better functioning , bet that paint would like a aerosol lubrication , spray down , let it soak , a day wipe down til clean / dry . get some aerosol penetrating oil into that manual lift lever , make the rust run out , only some suggestions , pete 1 Share this post Link to post Share on other sites
mike avad 41 #8 Posted July 6 Thank you all for you reply's and help info I would line to put a 14 or 16 HP on it but nothing but a Kohler engine 1 Share this post Link to post Share on other sites
ebinmaine 67,484 #9 Posted July 6 5 minutes ago, mike avad said: Thank you all for you reply's and help info I would line to put a 14 or 16 HP on it but nothing but a Kohler engine Any particular thing you're wanting to accomplish? Share this post Link to post Share on other sites
