pfrederi 17,741 #1 Posted July 5 Don't you love reassembling after an overhaul.... put in the gasket and two .005 spacers (as directed by the manual) Use your aligning pins get the bearing plate back on. Torque it down to 30 ftlbs find no end play (well less than .002) then have to set up your puller to get the plate back off put in the spacer and reassemble. Think from now on 3 spacers crank end play spec is pretty broad. 4 Share this post Link to post Share on other sites
ri702bill 8,327 #2 Posted July 5 It is always a race to the bottom line...! Share this post Link to post Share on other sites
953 nut 55,296 #3 Posted July 5 I always save the old gaskets and measure them then engrave the measurement on the bearing plat so I know what to put back in upon reassembly. 4 Share this post Link to post Share on other sites
