pfrederi
Kohler Bearing plate spacers
pfrederi
Don't you love reassembling after an overhaul.... put in the gasket and two .005 spacers (as directed by the manual)  Use your aligning pins get the bearing plate back on.  Torque it down to 30 ftlbs find no end play (well less than .002)  then have to set up your puller to get the plate back off put in the spacer and reassemble.  Think from now on 3 spacers crank end play spec is pretty broad.
  • Like 4
ri702bill
It is always a race to the bottom line...!
953 nut
I always save the old gaskets and measure them then engrave the measurement on the bearing plat so I know what to put back in upon reassembly.
  • Like 4
